To start, great program, always works for me with no major problems. Going to register very soon.
I think I found a strange little bug, this happens every time I use it.
Open makemkv.exe
Watching Process Explorer: I see that makemkv.exe spawns, then shortly thereafter makemkvcon64.exe spawns.
Close mkemkv.exe, using the standard File->Quit OR hitting the X
Watching Process Explorer: I see that makemkv.exe dies, leaving behind makemkvcon64.exe.
The makemkvcon64.exe process never dies, and constantly uses around 530MB of RAM.
System:
Windows XP x64 SP2
2.01 Ghz
4GB RAM
Bug? Zombie makemkvcon64.exe
- Contact:
Re: Bug? Zombie makemkvcon64.exe
It's a bug. Does it happen all the time? For example, will you get a zombie process if you start and instantly quit the application, or do you need to open a disc for it to stay?
Yes, it happens all the time... either open the program and then quit out OR open the program make an MKV then quit.
