MakeMKV licensing question
nanoman06
Post by nanoman06 » Mon Apr 01, 2019 2:53 am
I think I would like to buy a license for application but I need to know more about the install limits. Can the key be de-activated in the software and then re-used if the OS is reinstalled / new OS drive? Is there a limit or other process to allow this?
Grauhaar
Re: MakeMKV licensing question
Post by Grauhaar » Mon Apr 01, 2019 6:15 am
Yes, you can re-use the key after OS reinstallation, no problem
Good Luck :)
T'hain Esh Kelch
Post by T'hain Esh Kelch » Mon Apr 01, 2019 11:30 am
No need to de-install. It will work as many times as you need it. That being said, please don't share it.
mikey1273
Post by mikey1273 » Mon Apr 01, 2019 12:26 pm
I built myself a new PC to replace my old 10 year old Dell that will no longer boot. I have not been able to recover all the files. I purchased a license for Make MKV how can I get my Activation Key resent?
Post by Woodstock » Mon Apr 01, 2019 1:38 pm
Fastest is to find the email that was sent by either avangate.com or 2co.co with the key.
Otherwise, send an email to support@makemkv.com with your information from when you ordered it, and Mike will send you the key.
BlueMac77
Post by BlueMac77 » Mon Apr 01, 2019 4:03 pm
@nanoman06 I’ve changed computers and reformatted the OS many times and the key always works fine, no need for reactivation. MakeMKV is a proficient app and worth buying the license. It’s versatile that it works on all 3 platforms - Windows, Mac and Linux.
mikey1273
Post by mikey1273 » Mon Apr 01, 2019 5:07 pm
ESPNY
Post by ESPNY » Thu Nov 12, 2020 9:37 am
So you guys are saying that I could use my license simultaneously on my Mac AND PC? And reinstall it any time?
st4evr
Post by st4evr » Thu Nov 12, 2020 10:20 am
ESPNY wrote: Thu Nov 12, 2020 9:37 am So you guys are saying that I could use my license simultaneously on my Mac AND PC? And reinstall it any time?
Always been that way. Noted in the FAQ:
https://www.makemkv.com/forum/viewtopic.php?f=1&t=20579
