Heads up - Support for LG UHD drives
Re: Heads up - Support for LG UHD drives
#16 Post by Billycar11 » Sun Mar 31, 2019 6:33 pm
GyroDragona wrote: Sun Mar 31, 2019 4:17 pm
mike admin wrote: Wed Feb 06, 2019 1:22 am
spl147 wrote: Wed Feb 06, 2019 1:15 am what drives/firmwares are supported with this LibreDrive mode?
The detailed list will be posted soon. About 200 firmware versions total, about 2/3 in supported state. MakeMKV now displays detailed information for the drive on the main screen, look for the LibreDrive information on the right pane. It will tell you if the drive is supported right now or can be possibly supported.
Has the list been posted anywhere yet? My bluray drive died and I need to replace it but don't want to get something that might not be supported by LibreDrive.
https://www.makemkv.com/forum/viewtopic ... 145#p72096
Also if you don't want to flash the firmware your self I sell them pre flashed and tested https://www.makemkv.com/forum/viewtopic ... 16&t=17831
