Enter The Void failure
tucansam
#1 Post by tucansam » Sat Mar 30, 2019 9:41 pm
I can't get this one to go. Unless I uncheck *all* of the audio tracks. It starts, runs for 15-30 seconds, and then fails. Windows 7.
MakeMKV v1.14.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\bob/MakeMKV_log.txt
The new version 1.14.3 is available for download at http://www.makemkv.com/download/
Downloading latest SDF to C:\Users\bob/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
DEBUG: Code 89 at z3q2Zsw5q;dm{R\<:121274032
LibreDrive firmware support is not yet available for this drive (id=765540796806)
Title #00029.mpls has length of 0 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00021.mpls has length of 730 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00025.mpls has length of 320 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00023.mpls has length of 202 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00022.mpls has length of 431 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
File 00006.mpls was added as title #0
Title #00039.m2ts has length of 3 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00036.m2ts has length of 84 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00035.m2ts has length of 143 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00034.m2ts has length of 125 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00033.m2ts has length of 8 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00032.m2ts has length of 8 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00041.m2ts has length of 127 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00031.m2ts has length of 9 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00040.m2ts has length of 131 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00008.m2ts has length of 730 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00007.m2ts has length of 332 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00006.m2ts has length of 669 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00005.m2ts has length of 128 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00004.m2ts has length of 320 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00003.m2ts has length of 202 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00002.m2ts has length of 431 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Saving 1 titles into directory D:/Video/Enter The Void (2009) using profile 'AAC-stereo' from file 'C:\Program Files (x86)\MakeMKV/appdata.tar:aac-st.mmcp.xml'
FFMPEG_ERROR: FFDEC001: [dca @ 0000000012b0d6e0] Failed to decode block code(s)
DEBUG: Code 2 at l6^_w`bC)?2^kDMI:213132997
DEBUG: Code 0 at }vFN@KpabQ2CK7z+-/iZ:29393286
DEBUG: Code 20 at l6^_w`bC)?2^kDMI:29395195
DEBUG: Code 0 at l6^_w`bC)?2^kDMI:29397058
DEBUG: Code 0 at JP]{HWI?rAPa~'vx&5SN:29395011
DEBUG: Code 1 at '(?Zq2.A;"@kC(Q\:121263935
DEBUG: Code 0 at Si0V5Sd:mgl|*kGOu<s]#:213136608
Failed to save title 0 to file D:/Video/Enter The Void (2009)/Enter The Void_t00.mkv
0 titles saved, 1 failed
Re: Enter The Void failure
#2 Post by d00zah » Sat Mar 30, 2019 10:08 pm
1st off, there's an update... you should install it:
Next, MakeMKV is having an issue connecting to the 'mother ship':
Check that Preferences > General > 'Allow contacting web server for updates' is checked.
Restart MakeMKV & try the disc again.
There was also a recent program change regarding profiles:
This MIGHT be resolved with the update and/or an updated SDF?
tucansam
#3 Post by tucansam » Sat Mar 30, 2019 10:12 pm
I am blocking with pihole and my firewall.
Makemkv is trying to reach a host in Russia.
Safe?
#4 Post by d00zah » Sat Mar 30, 2019 10:14 pm
Not surprised, but I allow it & nothing nefarious has ever raised a fuss in all the time I've used MakeMKV.
I say "go for it".
This is how MakeMKV receives updates between version releases... UHD hash keys, LibreDrive updates, etc..
tucansam
#5 Post by tucansam » Sat Mar 30, 2019 10:18 pm
91.224.23.225
This is the host that Makemkv was trying to reach. I have allowed it, and updated my software. SDF download is successful.
Video still will not rip, however.
#6 Post by d00zah » Sat Mar 30, 2019 10:28 pm
d00zah wrote: Sat Mar 30, 2019 10:08 pm There was also a recent program change regarding profiles:
Or, might not. Are you using a modified AAC profile?
My guess is the 'AAC-stereo' profile is the issue & selecting 'default' will allow the rip. Try it for the sake of debug.
You've posted the debug output, but it'd probably be more expedient to shoot a log to support@makemkv.com .
