MakeMKV creates dozens of files for Hacksaw Ridge
rayda
#1 Post by rayda » Sat Mar 30, 2019 7:16 pm
Hello, I am using a USB Bluray drive in an attempt to rip my BluRay version of Hacksaw Ridge. I was using a 10 year old Mac with OSX 10.6. When I thought there was a bug there, I moved to my W10 pc to do the same operation with the same drive and disk. Both system ended up doing the same thing.
They appear to have found 407 different titles on the disk, and most of the titles are 33.2G in size. If I try to rip the whole disk, I get the following warning:
and indeed, if I let it go, it will run for days and use up terabytes of space. It seems like it wants to rip 400 copies of the 33G file.
The whole list looks like this (only a lot longer):
The first entry in the list:
What is the intended operation of this software? Most ripping software I've seen lists just the main movie to rip. Should I only rip the FPL_MainFeature? What are all the rest of the titles for?
OS device name: O:
Product: BD-RE BP50NB40
Revision: 1.01
Serial number: SIK7AHCPL4753
Firmware date: 2117-11-23 16:15
Highest AACS version: 62
Harware support: Yes
Firmware support: No
Firmware version: 1.01
Disc Information
Label: HACKSAW_RIDGE
Timestamp: 2016-12-20 22:52:55
Data capacity: 45.64 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
Re: MakeMKV creates dozens of files for Hacksaw Ridge
#2 Post by Woodstock » Sat Mar 30, 2019 8:19 pm
Welcome to the world of Lionsgate Obfuscation. Only the title marked "FPL_MainFeature" is real; the others with "16 chapter(s), 32 GB" next to them are fake, and you can unselect them (hint: RIGHT click with your mouse, "unselect all", then reselect the real titles).
See the sticky message in the general forum, "What is the correct play list [insert title here]?", for more information.
rayda
#3 Post by rayda » Sat Mar 30, 2019 9:30 pm
Thanks, Woodstock! That makes a lot more sense. And I'm going to read that article.
