MakeMKV's pristine UHD BD rips & their playback compatibility on (un)common devices
Do you care about playback compatibility of your UltraHD blu-ray backups / rips?
YES
21
88%
NO
1
4%
Forget about discs, streaming is the future!
2
8%
Total votes: 24
planet1
#1 Post by planet1 » Sun Aug 12, 2018 7:46 pm
If there is a need for a quick overview of devices capable of handling the playback of MakeMKV's UHD BD Rips, this is an attempt to create one:
  • Code: Select all
    Fabricator	Model		Device type	FW / OS-Version		SW / App	SW-Version		video playback	HDR handling	24p video mode	audio: TrueHD	DTS-HD MA	AC3	dts		subtitles	submitter
    LG		65SJ8509	television set	05.80.35		-		-			OK		OK		?			FAIL	OK		OK	OK		?
    Sony		UBP-X800M2	disc player	M45.R.0050		-		-			OK		OK		YES, 24p		OK	OK		OK	OK		FAIL
    Sony		UBP-X700	disc player	M43.R.0277		-		-			OK		OK		YES, 24p		FAIL	OK		OK	OK		?		RESET_9999
    Panasonic	DMP-UB314	disc player	1.82			-		-			OK		OK		NO, 60p			FAIL	FAIL		OK	OK		FAIL
    Microsoft	Xbox One S	game console	10.0.17763.4088		Media Player	2.6.425.0		OK		OK		NO, 60p			FAIL	FAIL		OK	FAIL		FAIL
    Microsoft	Xbox One S	game console	10.0.17763.4088		Film & TV	10.19021.1041.70	OK		OK		NO, 60p			FAIL	FAIL		OK	FAIL		OK
    Microsoft	Xbox One S	game console	10.0.17763.4088		VLC		3.1.0.70		FAIL		-		-			OK	FAIL		OK	OK		FAIL
    Dune HD		Pro 4K		set-top box	Android 7.01		?		?			OK		OK		YES, 24p		OK	OK		OK	OK				spl147
    NVIDIA		Shield (TV/Pro)	set-top box	Android 8.x		Kodi		18.1			OK		OK		YES, 24p		OK	OK		OK	OK		?		spl147
    MINIX		NEO U9-H	set-top box	Android 7.1.1		Kodi		18.1			OK		OK		YES, 24p		OK	OK		OK	OK		?		Grencola
Additional categories like subtitle support or chapter recognition could be added.
Looking forward to add all sort of devices like smartphones and tablets with MHL, SlimPort or USB-C [alternate modes] support.
One last thing: let's just leave PCs out of it, at least for now or until the Playstation (Pro) catches up ;-).
spl147
Re: MakeMKV's pristine UHD BD rips & their playback compatibility on (un)common devices
#2 Post by spl147 » Sun Aug 12, 2018 8:39 pm
Dune HD 4k PRO
spl147
#3 Post by spl147 » Tue Aug 14, 2018 1:22 pm
the dune is Android 7.01
Chip is RTD1295 rev.B
UHD playback yes
HDR yes
24P yes
TrueHD/Atmos yes
DTSHD/DTSX yes
AC3 yes
DTS yes
subtitle support coming in next firmware according to dune
annisman
#4 Post by annisman » Tue Aug 14, 2018 3:54 pm
Why are we leaving PC's out of the discussion ? The list for an HTPC is pretty short:
HTPC: Does everything ? A: Yes
:D
As far as MKV playback that is. It's kind of funny that PC's have falled off the grid when it comes to streaming. It's really a platform that COULD do everything (streaming wise) if only the streaming services/Windows would give it some love. Because it lacks in the streaming area I have a Roku Ultra (4K) for all the other stuff.
planet1
yippie yi yo ... the list is growing
#5 Post by planet1 » Tue Aug 14, 2018 9:20 pm
Because the variations are sheer endless: starting with the correct GPU, the os, the os patch level, the driver, the optimal driver settings, the playback software, the sw accelerated mode, the signal connection (HDMI, DP), the monitor etc.
Let's focus on uniformed environments, on which people can easily reproduce the playback capability.
MY bets are on Raspberry Pi 5 or 6 with a full 4K HEVC HDR decoding capability (hopefully) :roll: .
Last but not least, where are the smartphone nerds? A fairly recent Snapdragon, Android 8.x and a USB-C to HDMI adapter cable should do the job.
spl147
#6 Post by spl147 » Sun Mar 17, 2019 12:42 pm
nVidia Shield TV Using KODI 18
Android 8
KODI 18.1
UHD playback yes
HDR yes
24P yes
TrueHD/Atmos yes
DTSHD/DTSX yes
AC3 yes
DTS yes
Dolby Vision no
Grencola
#7 Post by Grencola » Fri Mar 29, 2019 11:21 pm
Android 8
KODI 18.1
UHD playback yes
HDR yes
24P yes
TrueHD/Atmos yes
DTSHD/DTSX yes
AC3 yes
DTS yes
Dolby Vision no
the same can be said for the minix u9-h.
or, you know, literally any cheap Chinese kodi box using amlogic s905x/s912 and soon s905x2/s922 (plus a bunch of rockchip soc's) running libreelec :p
planet1
Sony + Raspberry
#8 Post by planet1 » Sat Feb 01, 2020 12:33 am
*Added the Sony UBP-X800M2 UHD-disc player & the LG 65SJ8509 LED-TV-set.
*Rearranged device type order
*Added the Sony UBP-X700 - thanks @ RESET_9999
Looking forward to see reports on the Raspberry Pi 4, amazon Fire TV Stick 4K & many more.
