Heads up - Support for LG UHD drives
Re: Heads up - Support for LG UHD drives
No need to mount it internally. Depending on your USB case, it should be flashable from there without issue.
viewtopic.php?f=16&t=18933
Go there and get Marty's ASUS flasher.
viewtopic.php?f=19&t=19113
Go there and get Mike's MK firmware pack
Use the NS60 1.01 MK from Mike's zip and flash it with Marty's ASUS flasher in Windows and you should be good to go with LibreDrive.
Dave77
Isn't it just worth waiting until 1.01 is supported, do we know when that will be?
spl147
It is supported on 1.01 with MK patched firmwareDave77 wrote:Isn't it just worth waiting until 1.01 is supported, do we know when that will be?
The official 1.01 closed the communication of libredrive, thats why the MK patched 1.01 was released
Sent from my iPhone Xs Max using Tapatalk Pro
Dave77
I see, thanks. I'd thought the standard 1.01 fw was going to be supported eventuallyspl147 wrote: Thu Mar 21, 2019 8:13 pmIt is supported on 1.01 with MK patched firmwareDave77 wrote:Isn't it just worth waiting until 1.01 is supported, do we know when that will be?
spl147
Official 1.00 is supported.Dave77 wrote:I see, thanks. I'd thought the standard 1.01 fw was going to be supported eventuallyspl147 wrote: Thu Mar 21, 2019 8:13 pmIt is supported on 1.01 with MK patched firmwareDave77 wrote:Isn't it just worth waiting until 1.01 is supported, do we know when that will be?
Flashing the patched firmware takes like 2 mins. And works perfectly!
I flashed my BU40N (v.1.02) and my WH16NS60 (v.1.01)with MK patched firmware
I'm using NS60 1.01 MK, as well. Works great.
jonghotti
- Contact:
Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
So can anyone verify that with this interim MK firmware the BP60NB10 drive now works?
Is flashing over the USB port now possible?
spl147
I flashed both my BU40N and my WH16NS60 over usb, using vantec enclosuresjonghotti wrote:Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
Japio
That is something I would also like to know.jonghotti wrote: Fri Mar 22, 2019 1:54 pm Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
Still waiting for a response from support, for a long time now.
Try it and see. I have a feeling the flashers won't like the enclosure though. Still worth a try. It will either work or it won't.jonghotti wrote: Fri Mar 22, 2019 1:54 pm Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
jonghotti
- Contact:
So the USB cable that comes with the enclosure and that's it? What flasher needs to be used with this?spl147 wrote: Fri Mar 22, 2019 9:30 pm I flashed both my BU40N and my WH16NS60 over usb, using vantec enclosures
I desperately need to be able to dump the firmware off one of these BP60NB10s, get it cleaned, and get these fuckers working. They've been gathering dust for months. Thank you.
Alex
Alex,jonghotti wrote: Sun Mar 24, 2019 2:21 amSo the USB cable that comes with the enclosure and that's it? What flasher needs to be used with this?spl147 wrote: Fri Mar 22, 2019 9:30 pm I flashed both my BU40N and my WH16NS60 over usb, using vantec enclosures
Alex
Try the modified ASUS flasher from viewtopic.php?f=16&t=18933 to flash it.
Both the LG and the ASUS flashers can be a bit picky with some enclosures & SATA / USB adapter cables though, so you may get an error. It's worth a try though. If the flashing works then Mike's MK firmware is all you need for this drive (assuming it is UHD friendly?).
Let us know how you go!
PS: There is still no way other than DOSFLASH to dump a firmware though. I assume Mike extracted the firmware from the official LG BP60NB10 flasher and made his modifications to it.
jonghotti
- Contact:
I need to get confirmation from him that the initial dump and cleaning has been done. That’s been on my list of things to do for awhile and I’ve got 5 of these bad boys to sell.
spl147
If it’s in his MK firmware package then it’s ready! No need to dump it, those days are over!!!! Try it and find out
- Contact:
emphasis mine. There are still few methods available, that work over USBMartyMcNuts wrote: Sun Mar 24, 2019 2:40 amPS: There is still no (public) way other than DOSFLASH to dump a firmware though.
