UHD USB drives (or laptop slimline?)
Hi All-
Apologies if this is covered elsewhere...I tried to search for relevant terms and didn't see anything obvious.
I use MacOS on a MacBook Pro and MacMini. Both those use slimline laptop drives. Are there any MacOS friendly UHD drives that are either:
1) slimline that can retrofit into either of the above cases, or
2) USB3 compatible that I can use as a standalone
yw.
yw.
Re: UHD USB drives (or laptop slimline?)
The BU40N is a 9.5mm slim UHD drive.YouWho wrote: ↑Wed Mar 20, 2019 7:54 pmHi All-
yw.
A good external option is the Archgon MD-8107S-U3-UHD. The drive inside the Archgon is also a BU40N.
You can find them both on Amazon.
I've been tempted to splurge on the Pioneer BDR-XD07J UHD Blu-Ray drive, with an USB Type-C connector which looks as slim as it can get and an absolute beast for reading media on the go. However, I read that Pioneer drives are a poor choice for MakeMKV.
yes they are a poor choice for now unless your pc meets the powerdvd requirements and you just want to watch them
Currently Pioneer drives are not good if you want to back-up your UHD discs. No ripping software is compatible with them. This is why we always recommend the LG or ASUS drives.
BU40N in Vantec enclosure. You want one of these and should email me to get one. alexcoluzzi32@gmail.com
I now return to finishing off the units owed to people who have been waiting patiently.
Oh, well, I'm in the EU so I hardly think it would worth it, but I did see your units here in the forum and I think they're awesome.jonghotti wrote: ↑Sun Mar 24, 2019 2:29 amBU40N in Vantec enclosure. You want one of these and should email me to get one. alexcoluzzi32@gmail.com
Shipping to the EU is only $24 USD
Hi again-
Sorry, I was on holidays and just got this reply (thanks to MartyMc). I ordered the Archgon external so I could pass it between my MBP and MB Air as needed. Do I need to deal with firmware upgrade or downgrade on this unit? If so, is there a MACOS option for that or do I need to hijack my wife's Win10 worktop?
thanks again!
yw.
thanks again!
yw.
MartyMcNuts wrote: ↑Thu Mar 21, 2019 12:24 amThe BU40N is a 9.5mm slim UHD drive.YouWho wrote: ↑Wed Mar 20, 2019 7:54 pmHi All-
yw.
it may need a downgrade the Archgon i got had 1.01 and needed to be downgraded if you have a win 10 pc in the house it will be easier then setting up a vm of windows on mac thats the only way on mac for now.YouWho wrote: ↑Tue Jul 30, 2019 12:01 amHi again-
thanks again!
yw.
You will most likely have to downgrade the firmware and yes, the quickest and easiest way is using a windows machine.YouWho wrote: ↑Tue Jul 30, 2019 12:01 amHi again-
thanks again!
yw.
yw.
Gotcha. Assuming that the tutorials cover the how-to's in the root post of this forum (?). As a former UNIX hacker, should i assume there is now straight forward command line or otherwise option on MacOS's bastard child *NIX-esque system?MartyMcNuts wrote: ↑Tue Jul 30, 2019 12:15 amYou will most likely have to downgrade the firmware and yes, the quickest and easiest way is using a windows machine.YouWho wrote: ↑Tue Jul 30, 2019 12:01 amHi again-
thanks again!
yw.
