Custom firmware pack with LibreDrive patches - discussion
BermudaLamb
Post by BermudaLamb »
When will the
detailed flashing instructions be posted?
Re: Custom firmware pack with LibreDrive patches
BermudaLamb wrote: Wed Mar 27, 2019 2:20 am When will the
pretty much just follow this video: https://www.youtube.com/watch?v=Yfpf6HoMMis
and make sure your drive meets the requirements
you know
ns50 or 60 svc code on drive
2015+ build date
MT1959 Drive platform under LibreDrive Information in makemkv
stuff like that
sickb
Post by sickb »
Do we still use the `BH16NS40_EEPROM_Data_Mover.exe` to copy info from the currently installed official firmware, to the new MK firmware?
sickb wrote: Fri Mar 29, 2019 9:40 am Do we still use the `BH16NS40_EEPROM_Data_Mover.exe` to copy info from the currently installed official firmware, to the new MK firmware?
No if you had watched the video I posted above you would know that
sickb
Post by sickb »
alright, but the asus tool throws an error on my win PE, so I am left to the old tools that were recommended to be used with the data mover,
in this case im cross-flashing LG BH16 NS55 to Asus.
Post by SamuriHL »
No, please don't do that.
https://www.makemkv.com/forum/viewtopic ... 284#p70284
Use the unlocked LG Windows flasher in that post. The flasher you're using requires .net to be installed which is why you're getting an error in WinPE but it's not the only Windows flasher. The old dosflash method is not needed.
sickb
Post by sickb »
SamuriHL wrote: Fri Mar 29, 2019 8:34 pm No, please don't do that.
many thanks!
cbickel
Post by cbickel »
Anyone had any luck using the custom MK firmware for incompatible drives. I have an LG BP50NB40 NB50. There is a custom firmware bin file in the directory for my drive. However, when I try to use the unlocked flasher it gets stuck at 0%. Any help would be appreciated.
jonghotti
Post by jonghotti »
cbickel wrote: Sat Mar 30, 2019 4:13 pm Anyone had any luck using the custom MK firmware for incompatible drives. I have an LG BP50NB40 NB50. There is a custom firmware bin file in the directory for my drive. However, when I try to use the unlocked flasher it gets stuck at 0%. Any help would be appreciated.
Pretty sure this was Woodstock's job, since he has one :-) Hey buddy!
I may have one, but it isn't regularly hooked up to anything, since it's for my laptop.
Since mine came with firmware that LibreDrive recognized, I've not had reason to dump or flash the firmware... Luck of the firmware draw, I guess... ;)
tcafranz
Post by tcafranz »
jonghotti wrote: Sun Mar 31, 2019 5:16 am
sooooooo I'm SOL with this BP50NB40 NB50 on 1.01?
rogodeter
Post by rogodeter »
Has anybody created tools/instructions for flashing my drives while running Linux? I don't have Windows and my drives are internal so moving it to a friend's machine is not trivial.
Thanks,
spl147
Post by spl147 »
rogodeter wrote:Has anybody created tools/instructions for flashing my drives while running Linux? I don't have Windows and my drives are internal so moving it to a friend's machine is not trivial.
Thanks,
Boot from a windows live USB
Sent from my iPhone Xs Max using Tapatalk Pro
jonghotti
Post by jonghotti »
Woodstock wrote: Sun Mar 31, 2019 2:12 pm I may have one, but it isn't regularly hooked up to anything, since it's for my laptop.
OK let me try it another way, Mr. Woodstock, would you please share a copy of your drive's firmware with us?
Thank you very much!,
Alex, and the rest of the grateful makemkv forum users and license holders.
tcafranz
Post by tcafranz »
jonghotti wrote: Sat Apr 20, 2019 7:26 pm
Por favor senor
