Application Failed to Initialize - finally fixed for me
bib1963
Post by bib1963 » Wed Mar 13, 2019 7:23 pm
So, 1.14.* all failed.
I have an x64 system, and all 64bit libs on openSuse should be in /usr/lib64
A search for libmakemkv.so.1 found an old 64bit version in /usr/lib.
Removing that, as well as libdriveio.so.0 & libmmbd.so.0 in /usr/lib, FINALLY got makemkv to work.
It was picking up a version from 2 years ago. I assume < 1.14 copied the libs into /usr/lib and 1.14 into /usr/lib64, and the old ones were never removed.
Only problem I have now, is makemkv says the disc is called LOGICAL_VOLUME_ID, & each title is of the form, title_t01.mkv. Ah well, can't have everything I suppose.
Wagonfixin
Re: Application Failed to Initialize - finally fixed for me
Post by Wagonfixin » Fri Mar 15, 2019 3:04 am
Hey! Thanks for documenting this! I was smacking my head on the keyboard - This fixed it for me too!
Topher
Post by Topher » Sun Mar 24, 2019 5:43 pm
Yes, thank you!
How did you come to find out these files were the culprit?
aelthwin
Post by aelthwin » Tue Sep 03, 2019 5:06 pm
Worked for me on OpenSUSE Leap 15.0
tuxtv
Post by tuxtv » Wed Oct 07, 2020 12:06 pm
Same here with Tumbleweed. Those old libraries were just lurking around until at least 1.15.1, but are not part any more in 1.15.3.
Good work, pal!
jvian1
Post by jvian1 » Thu Oct 08, 2020 1:26 am
The duplicate libraries were what hosed me up as well.
Upgrading from 1.14.5 to 1.15.3 and got the same error.
Found duplicates of libmakemkv.so.1, libdriveio.so.0 and libmmbd.so.0 in both /dev/lib and /dev/lib64. Guess that confused the linker.
Manually removed all, reinstalled 1.15.3 and all was well.
I hope the maintainer can fix the install process to remove old libraries during the install so the leftovers are not a problem going forward.
aurik
Post by aurik » Tue Oct 13, 2020 6:29 pm
I found another version in /usr/lib/x86_64-linux-gnu that I had to remove. Apparently that came from a "snap" makemkv install.
