Video files disappeared?
dom61
#1 Post by dom61 » Fri Aug 20, 2010 6:12 am
Good morning.
Opening the folder decrypted blu-ray, not the video file I get H264,
MakeMKV do not complete the conversion.
This happens with the Blu-ray AVATAR after it was made remuxing with tsMuxeR
here is the debug
Debug log started at Thu Aug 19 12:51:52 2010 , written by MakeMKV v1.5.8 win(x86-release)
001005:0000 MakeMKV v1.5.8 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\MIMMO/MakeMKV_log.txt
003006:0000 Opening files on harddrive at F:/04 Blu-ray in lavorazione/03- Muxed Film/AVATAR/
003305:0000 AACS directory not present, assuming unencrypted disc
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
001003:0020 DEBUG: Code 7 at 3![[b0&MGbn2"v'ZTCA,:213133181
001003:0020 DEBUG: Code 0 at Oy!ub2q;J4=`E+L}|J}?g:29397449
001001:0020 DBG ASSERT: sw?L%xzmuPTQ>8ISgLSuzsN_;HY8c*"<= at '~E';7~_`s"QGsW:W//:121261589
003307:0000 File 00000.mpls was added as title #0
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory F:/06 Blu ray convertiti MKV
001003:0020 DEBUG: Code 0 at Oy!ub2q;J4=`E+L}|J}?g:121265775
001003:0020 DEBUG: Code 0 at l_zlxE7Q^,2`8 .Rw,0:213130490
001003:0020 DEBUG: Code 0 at l_zlxE7Q^,2`8 .Rw,0:121263567
005003:0000 Failed to save title 0 to file F:/06 Blu ray convertiti MKV/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Thu Aug 19 12:52:11 2010
Trying another conversion tool mkv the procedure is completed successfully.
What can be ilo problem?
THANKS
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
setarip_old
Re: Video files disappeared?
#2 Post by setarip_old » Sat Aug 21, 2010 2:40 am
Hi!
1) What is your source material? (Original BluRay, original Bluray decrypted by AnyDVD HD, something else)
2) What do you have "minimum file length" set to?
#3 Post by mike admin » Wed Aug 25, 2010 7:45 am
From the log file it's a custom-made blu-ray disc not conforming to blu-ray specification. MakeMKV can't process such discs.
