Current profile: DVD-ROM
Product: BD-RE WH16NS40
Revision: 1.03
Serial number: M65IAMG1310
Firmware date: 2117-11-21 16:53
Harware support: Yes
Firmware support: No
Firmware version: 1.03
so it looks like I can get libredrive mode with a firmware patch if I am interpreting this correctly.
My question to you guys is this: How would I go about doing that, and how risky is it from a chance of bricking drive perspective?
Revision: 1.03
WARNING: IF THIS DRIVE IS NOT REASONABLY NEW (as in older than late 2015) then do not flash it.
However, I'm assuming this is a fairly new drive since it has firmware 1.03 on it. You can make sure by checking for the SVC NS50 code on the drive label.
If this is the case, you can download either of the modified flashers + firmware and easily flash your drive. (Both the ASUS & LG flashers do the same thing)
It's very easy to do and there is very little chance of doing any damage.
Let us know how you go!
Ok so, quick pull and reinstall later here is my drive label: https://imgur.com/HUnDKN1
I have noticed in the mk firmware pack under HL-DT-ST (which I think is the right spot for my drive) there are 2 different WH14NS40 firmware files; both labeled WH16NS40-NS50, are they the same? If not how do I tell which to use? And most importantly are these the right files for my drive?
Update: Realized there was only one firmware in the folder and I had read it wrong. Downloaded the mk firmware and flasher tool, pushed one button selected one file, it took thirty seconds and worked perfectly couldn't be happier. Thanks for the help you guys! Don't have a UHD disk to test atm but a regular blue ray I have that was rate limited to like 1 or 2x appears to be running at like 4x now.
Edit: above 5x now, big improvement!
Hime0698 wrote: Sat Mar 23, 2019 11:00 pm
Excellent! I was about to mention there is only 1 WH16NS40-NS50 folder in the MK firmwares. Glad you figured that one out.
My drive is WH16NS40 without the -NS50 after it. I bought it in 2018 and the version is 1.2. The drive says it was made in 2016. I downloaded the MK firmware files but I only see folders with WH16NS40-NS50 or WH16NS40-NB50. What do I use and how do I update the firmware?
I have attached a screenshot of my drive information.
I am using Unraid with MKV version 1.14.3
Thank you!
Screen Shot 2019-03-26 at 5.13.43 PM.png (146.67 KiB) Viewed 23239 times
SkippyTheMagnificent wrote: Tue Mar 26, 2019 9:18 pm
I have a similar question as the original poster.
Thank you!
It appears to recognize UHD discs. Why do you need to update it?
