The Killer
TonyUniopolis
The Killer
Post by TonyUniopolis »
Having problems ripping the recent BluRay release of "The Killer"
The film and the larger supplements are procesed successfully. 10 of the supplements (mostly Deleted Scenes) fail with the following errors:
Saving 10 titles into directory H:/MKV2
DEBUG: Code 0 at WA*P6Sd[Bp}5#Ej=6UU:29394574
DEBUG: Code 0 at Oy!ub2q;J4=`E+L}|J}?g:29397449
Failed to save title 1 to file H:/MKV2/title01.mkv
The disc plays fine in the same drive I am ripping from..and I am using the original media...
I am attaching the complete log.
Love the program so far!
Bill
Re: The Killer
Post by mike admin »
You have found a bug that could happen pretty much only on deleted scene. Will be corrected in the next version. As a workaround, you can copy these scenes if you de-select all subtitles.
TonyUniopolis
Re: The Killer
Thanks Mike! I'll be looking for the next version...keep up the great work! :D
