How to rip BD from hardrive version?
thewallace
#1 Post by thewallace » Sat Mar 23, 2019 12:25 pm
When ripping a BD I ran into the attached error. Could be due to either the disk or my drive. So I decided to copy the entire disc to my hardrive and rip from there. I was able to copy all the BD contents over with no issues.
--My question is how do I covert the HD version to a mkv? Makemkv recognizes the structure from a physical BD, but how do I get it to rip from a BD contents on a hardrive? I can't see a way to select the HD version to begin the process.
wmcclain
Re: How to rip BD from hardrive version?
#2 Post by wmcclain » Sun Mar 24, 2019 1:46 pm
"Open File" and select index.bdmv
#3 Post by Woodstock » Sun Mar 24, 2019 2:27 pm
For the original error, did you see this message? https://makemkv.com/forum/viewtopic.php?f=19&t=18833
If you "just" copied the disk to your drive, you will also need to get the key information from the disk, so MakeMKV can decrypt it. Creating a "non-decrypted backup" will save that information automatically; if you get a "Volume key is unknown" error with opening the disk as wmcclain says, I'll point you to that information.
thewallace
#4 Post by thewallace » Sun Mar 24, 2019 10:01 pm
I'm not getting any hash errors despite it not being listed in the current keys_hashed file. Its Dances with Wolves theatrical version from the Steelbox edition...btw.
The error points to a bad disc because it keeps failing at the same spot. But...my BD drive is embarrasingly old. I just ordered a new one that should be here tues. I'll test again then.
thewallace
#5 Post by thewallace » Mon Mar 25, 2019 10:53 pm
Well...I just replaced my old Lite-On BD drive with a new LG WH14NS40. It blazed through reading the disc in 1/4 of the time without slowing and made a seamless mkv. Really surprised me.
So in my case at least the error shown at the top of the post was solved by using a new drive. Go figure.
