Which CPU for fast ripping
ArcNad
Post by ArcNad »
Hi Guys,
i want to build a new HTPC with a UHD Frienly Drive and Make MKV.
At first i thinked about a AMD Ryzen 7 2700 CPU for ripping my disks (i have a lot of Discs). What do you think for CPU i should take for fast ripping? Or is the speed from ripping time from any CPU not a big difference?
Can you please say me how long is the normal time for ripping UHD Discs and blu ray Discs?
Thank you very much.
Regards.
ArcNad
Re: Which CPU for fast ripping
CPU is not the limiting factor in ripping - disk speed (both optical and otherwise) are the biggest factors.
I've run 2 drives to their speed limits on a 2-core 32-bit computer, pushing data out to a fast network drive. I've also done "triple rips" on a i5 3.4GHz machine while it was also doing a handbrake encode.
If you WANT a faster processor, that's OK, too... Just because MakeMKV would not benefit from it, once you get to encoding, more speed is good.
