Asus BW-16D1HT 3.03
Re: Asus BW-16D1HT 3.03
Post by MartyMcNuts » Tue Mar 19, 2019 8:14 am
@mfraz74,
I don't think it will work that way.
Just create and boot from a windows10PE usb stick and it will take all of 30 seconds to flash the drive.
mfraz74
Post by mfraz74 » Tue Mar 19, 2019 11:27 am
@mfraz74,
Tried following the instructions here http://www.webupd8.org/2013/07/how-to-c ... o.html?m=1 and adding the required .exe and .bin files but it won't work. I presume I need to add .net somehow?
mfraz74
Post by mfraz74 » Tue Mar 19, 2019 11:54 am
Is anyone able to create the required .iso with WinPE, the Asus FW changer and ASUS-BW-16D1HT-3.03-WM00000-211801191558.bin file on it and upload it to WeTransfer or somewhere?
Post by mike admin » Tue Mar 19, 2019 1:02 pm
SamuriHL wrote:
Sun Mar 17, 2019 9:57 pm
WARNING: DO NOT upgrade the drive to the new 3.10 firmware that ASUS just released. Doing so will (for now) remove the ability to downgrade and remove LibreDrive compatibility. Until Mike has a chance to patch that firmware, but, there's ZERO benefit in upgrading to it anyway. Stick with the MK 3.03 or DE 3.02 and you'll be good to go.
Just FYI - the MK firmware based on 3.10 is available and seems to be superior to 3.03/3.02 . If you flashed the official 3.10 by mistake, the downgrade patch is still available (official 3.10 won't allow downgrade, even to DE firmware) :
3.10 can be flashed to 3.10MK
3.10 MK can be flashed with any DE firmware.
Post by SamuriHL » Tue Mar 19, 2019 1:17 pm
Awesome thanks, Mike!
Sent from my Pixel XL using Tapatalk
Post by MartyMcNuts » Tue Mar 19, 2019 10:57 pm
PM sent
mfraz74
Post by mfraz74 » Wed Mar 20, 2019 7:40 am
Someone kindly sent me a Win10PE iso, but when I try to run ASUS_ODD_FW_Changer, I get "The application was unable to start correctly (0xc0000135),
mfraz74
Post by mfraz74 » Wed Mar 20, 2019 7:51 am
Looks like Microsoft.NET wasn't added as the 2.0.5727 directory is empty.
mfraz74
Post by mfraz74 » Wed Mar 20, 2019 11:43 am
Finally able to rip 4K blu-rays after upgrading the firmware to 3.10. Many thanks to MartyMcNuts.
Post by MartyMcNuts » Wed Mar 20, 2019 11:51 am
You're welcome 😊
computermoose44
Post by computermoose44 » Wed Mar 20, 2019 4:19 pm
MartyMcNuts wrote:
Tue Mar 19, 2019 4:28 am
computermoose44 wrote:
Mon Mar 18, 2019 11:06 pm
Hey Guys,
I am having similar trouble as the OP, same drive, same firmware. I first tried flashing with the new MK 3.03 firmware. MakeMKV still says
MakeMKV v1.14.3 win(x64-release) started
Saved SD dump file as C:\Users\School/.MakeMKV/dump_SD_BEBB0710929BC4F2D5A3.tgz
Downloading latest SDF to C:\Users\School/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
Downloading latest HK to C:\Users\School/.MakeMKV ...
Saved AACS dump file as C:\Users\School/.MakeMKV/MKB20_v61_Fantastic_Beasts_and_Where_to_Find_Them_8C29.tgz
I also tried to downgrade to 3.02 DE as suggested by the forums.
Same result. Any ideas?
You need to make sure that "Allow contacting web server for updates" is enabled (ticked) in Preferences (General tab).
Never made the connection to the failed downloading, i had a kids web filter running, once i disabled all was well. do you all recommend going up to 3.10 now that its been released?
computermoose44
Post by computermoose44 » Wed Mar 20, 2019 4:20 pm
SamuriHL wrote:
Tue Mar 19, 2019 4:29 am
And that you have no firewall rules blocking it. We've seen both issues lately.
thanks, it was a kids web filter that was getting in the way. You guys rock!
Post by SamuriHL » Wed Mar 20, 2019 6:28 pm
I absolutely recommend the MK 3.10 firmware for that drive. Has been the most stable firmware I've seen on it yet.
bobwalton
Post by bobwalton » Sat Mar 23, 2019 5:21 am
I am getting the same error on 3.10MK and 3.02 using the ASUS drive. The error says
Downloading latest SDF to C:\Users\Brian/.MakeMKV ...
DEBUG: Code 88 at 3n|Kn0<$@PHq+zen:121274009
Downloading latest HK to C:\Users\Brian/.MakeMKV ...
DEBUG: Code 0 at 3n|Kn0<$@PHq+zen:29399473
DEBUG: Code 0 at jFJ/sedl|n^h9"'$:29396115
DEBUG: Code 0 at jFJ/sedl|n^h9"'$:213134262
I do not understand how to make sure that the firewall is not blocking the connection. I turned the Windows 10 firewall off completely and get the same error.
Post by SamuriHL » Sat Mar 23, 2019 1:33 pm
Something on your system is blocking the download or you have the option to connect online disabled in the makemkv settings.
