Little bit of help needed
Hime0698
Post by Hime0698 »
Hi guys, I have an LG WH16NS40 drive with the following info dump
Current profile: DVD-ROM
Product: BD-RE WH16NS40
Revision: 1.03
Serial number: M65IAMG1310
Firmware date: 2117-11-21 16:53
Harware support: Yes
Firmware support: No
Firmware version: 1.03
so it looks like I can get libredrive mode with a firmware patch if I am interpreting this correctly.
My question to you guys is this: How would I go about doing that, and how risky is it from a chance of bricking drive perspective?
Re: Little bit of help needed
Hime0698 wrote: Sat Mar 23, 2019 3:04 am Hi guys, I have an LG WH16NS40 drive with the following info dump
Revision: 1.03
WARNING: IF THIS DRIVE IS NOT REASONABLY NEW (as in older than late 2015) then do not flash it.
However, I'm assuming this is a fairly new drive since it has firmware 1.03 on it. You can make sure by checking for the SVC NS50 code on the drive label.
If this is the case, you can download either of the modified flashers + firmware and easily flash your drive. (Both the ASUS & LG flashers do the same thing)
Flashers & firmware:
viewtopic.php?f=16&t=18933
viewtopic.php?f=16&t=18873
There are also some new (MK) firmwares available that were created by Mike(admin):
viewtopic.php?f=19&t=19113
It's very easy to do and there is very little chance of doing any damage.
Let us know how you go!
Hime0698
Post by Hime0698 »
I bought the drive in december so its fairly new. What code should I be looking for on the drive label?
Hime0698
Post by Hime0698 »
Ok so, quick pull and reinstall later here is my drive label: https://imgur.com/HUnDKN1
I have noticed in the mk firmware pack under HL-DT-ST (which I think is the right spot for my drive) there are 2 different WH14NS40 firmware files; both labeled WH16NS40-NS50, are they the same? If not how do I tell which to use? And most importantly are these the right files for my drive?
Hime0698
Post by Hime0698 »
Update: Realized there was only one firmware in the folder and I had read it wrong. Downloaded the mk firmware and flasher tool, pushed one button selected one file, it took thirty seconds and worked perfectly couldn't be happier. Thanks for the help you guys! Don't have a UHD disk to test atm but a regular blue ray I have that was rate limited to like 1 or 2x appears to be running at like 4x now.
Edit: above 5x now, big improvement!
Hime0698 wrote: Sat Mar 23, 2019 11:00 pm Update: Realized there was only one firmware in the folder and I had read it wrong. Downloaded the mk firmware and flasher tool, pushed one button selected one file, it took thirty seconds and worked perfectly couldn't be happier. Thanks for the help you guys! Don't have a UHD disk to test atm but a regular blue ray I have that was rate limited to like 1 or 2x appears to be running at like 4x now.
Excellent! I was about to mention there is only 1 WH16NS40-NS50 folder in the MK firmwares. Glad you figured that one out.
SkippyTheMagnificent
Post by SkippyTheMagnificent »
I have a similar question as the original poster.
My drive is WH16NS40 without the -NS50 after it. I bought it in 2018 and the version is 1.2. The drive says it was made in 2016. I downloaded the MK firmware files but I only see folders with WH16NS40-NS50 or WH16NS40-NB50. What do I use and how do I update the firmware?
I have attached a screenshot of my drive information.
I am using Unraid with MKV version 1.14.3
Thank you!
Screen Shot 2019-03-26 at 5.13.43 PM.png (146.67 KiB) Viewed 23238 times
SkippyTheMagnificent wrote: Tue Mar 26, 2019 9:18 pm I have a similar question as the original poster.
Thank you!
It appears to recognize UHD discs. Why do you need to update it?
