Heads up - Support for LG UHD drives
xxcalibur
Re: Heads up - Support for LG UHD drives
#196 Post by xxcalibur » Mon Mar 11, 2019 9:02 pm
hey mate..will your quide work with this model? WH14NS40 with SVC: NS40?
i have an old NS40 but i see where the original post called out the same drive but an SVC of NS50...just curious if it will work.
thanks
xxcalibur
#197 Post by d00zah » Mon Mar 11, 2019 9:21 pm
xxcalibur wrote: Mon Mar 11, 2019 9:02 pm hey mate..will your quide work with this model? WH14NS40 with SVC: NS40?
thanks
xxcalibur
No. If you try, bad things happen. See:
viewtopic.php?f=16&t=19071
viewtopic.php?f=16&t=18873&start=75#p71423
xxcalibur
#198 Post by xxcalibur » Mon Mar 11, 2019 10:55 pm
yeah i figured it wouldn't work but it doesn't hurt to ask LOL. i did just buy and install a new LG WH16NS60. just waiting for the program to accept it so i can start backing up my 4k collection.
thanks d00zah
#199 Post by d00zah » Mon Mar 11, 2019 11:09 pm
xxcalibur wrote: Mon Mar 11, 2019 10:55 pm yeah i figured it wouldn't work but it doesn't hurt to ask LOL. i did just buy and install a new LG WH16NS60. just waiting for the program to accept it so i can start backing up my 4k collection.
thanks d00zah
Now THAT one's possible... fairly straight forward.
viewtopic.php?f=16&t=18933#p70766
BermudaLamb
#200 Post by BermudaLamb » Thu Mar 21, 2019 1:50 pm
I'm running a pc on Windows 10.
I have a brand new LG WH16NS60 v1.01 installed in a USB3.0 drive case. This was purchased because it was indicated on the forum that this is one of the "official" supported UHD drives.
I've tried to use the latest version of MakeMKV to read many of my 4kUHD movie discs. All have failed with a SCSI read error.
Step-by-step, what exactly do I need to do in order to get this "official" drive to work with MakeMKV and my library of 4kUHD discs.
Do I need to mount it internally?
Do I need to change the firmware?
Do I need to install LibreDrive?
Please ... provide guidance and instructions, along with any appropriate links.
#201 Post by SamuriHL » Thu Mar 21, 2019 5:08 pm
No need to mount it internally. Depending on your USB case, it should be flashable from there without issue.
Go there and get Marty's ASUS flasher.
viewtopic.php?f=19&t=19113
Go there and get Mike's MK firmware pack
Use the NS60 1.01 MK from Mike's zip and flash it with Marty's ASUS flasher in Windows and you should be good to go with LibreDrive.
Dave77
#202 Post by Dave77 » Thu Mar 21, 2019 7:10 pm
Isn't it just worth waiting until 1.01 is supported, do we know when that will be?
spl147
#203 Post by spl147 » Thu Mar 21, 2019 8:13 pm
Dave77 wrote:Isn't it just worth waiting until 1.01 is supported, do we know when that will be?
It is supported on 1.01 with MK patched firmware
The official 1.01 closed the communication of libredrive, thats why the MK patched 1.01 was released
Sent from my iPhone Xs Max using Tapatalk Pro
Dave77
#204 Post by Dave77 » Thu Mar 21, 2019 8:24 pm
spl147 wrote: Thu Mar 21, 2019 8:13 pm
I see, thanks. I'd thought the standard 1.01 fw was going to be supported eventually
spl147
#205 Post by spl147 » Thu Mar 21, 2019 8:25 pm
Official 1.00 is supported.
Flashing the patched firmware takes like 2 mins. And works perfectly!
I flashed my BU40N (v.1.02) and my WH16NS60 (v.1.01)with MK patched firmware
#206 Post by SamuriHL » Thu Mar 21, 2019 8:36 pm
I'm using NS60 1.01 MK, as well. Works great.
jonghotti
#207 Post by jonghotti » Fri Mar 22, 2019 1:54 pm
Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
So can anyone verify that with this interim MK firmware the BP60NB10 drive now works?
Is flashing over the USB port now possible?
spl147
#208 Post by spl147 » Fri Mar 22, 2019 9:30 pm
jonghotti wrote:Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
I flashed both my BU40N and my WH16NS60 over usb, using vantec enclosures
Japio
#209 Post by Japio » Sat Mar 23, 2019 3:37 pm
jonghotti wrote: Fri Mar 22, 2019 1:54 pm Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
That is something I would also like to know.
Still waiting for a response from support, for a long time now.
#210 Post by MartyMcNuts » Sat Mar 23, 2019 11:31 pm
Try it and see. I have a feeling the flashers won't like the enclosure though. Still worth a try. It will either work or it won't.
