Heads up - Support for LG UHD drives
xxcalibur
Re: Heads up - Support for LG UHD drives
Post by xxcalibur »
hey mate..will your quide work with this model? WH14NS40 with SVC: NS40?
i have an old NS40 but i see where the original post called out the same drive but an SVC of NS50...just curious if it will work.
thanks
xxcalibur
Post by d00zah »
xxcalibur wrote: Mon Mar 11, 2019 9:02 pm hey mate..will your quide work with this model? WH14NS40 with SVC: NS40?
thanks
xxcalibur
No. If you try, bad things happen. See:
viewtopic.php?f=16&t=19071
viewtopic.php?f=16&t=18873&start=75#p71423
xxcalibur
Post by xxcalibur »
yeah i figured it wouldn't work but it doesn't hurt to ask LOL. i did just buy and install a new LG WH16NS60. just waiting for the program to accept it so i can start backing up my 4k collection.
thanks d00zah
Post by d00zah »
xxcalibur wrote: Mon Mar 11, 2019 10:55 pm yeah i figured it wouldn't work but it doesn't hurt to ask LOL. i did just buy and install a new LG WH16NS60. just waiting for the program to accept it so i can start backing up my 4k collection.
thanks d00zah
Now THAT one's possible... fairly straight forward.
viewtopic.php?f=16&t=18933#p70766
BermudaLamb
Post by BermudaLamb »
I'm running a pc on Windows 10.
I have a brand new LG WH16NS60 v1.01 installed in a USB3.0 drive case. This was purchased because it was indicated on the forum that this is one of the "official" supported UHD drives.
I've tried to use the latest version of MakeMKV to read many of my 4kUHD movie discs. All have failed with a SCSI read error.
Step-by-step, what exactly do I need to do in order to get this "official" drive to work with MakeMKV and my library of 4kUHD discs.
Do I need to mount it internally?
Do I need to change the firmware?
Do I need to install LibreDrive?
Please ... provide guidance and instructions, along with any appropriate links.
Post by SamuriHL »
No need to mount it internally. Depending on your USB case, it should be flashable from there without issue.
Go there and get Marty's ASUS flasher.
viewtopic.php?f=19&t=19113
Go there and get Mike's MK firmware pack
Use the NS60 1.01 MK from Mike's zip and flash it with Marty's ASUS flasher in Windows and you should be good to go with LibreDrive.
Dave77
Post by Dave77 »
Isn't it just worth waiting until 1.01 is supported, do we know when that will be?
spl147
Post by spl147 »
Dave77 wrote:Isn't it just worth waiting until 1.01 is supported, do we know when that will be?
It is supported on 1.01 with MK patched firmware
The official 1.01 closed the communication of libredrive, thats why the MK patched 1.01 was released
Sent from my iPhone Xs Max using Tapatalk Pro
Dave77
Post by Dave77 »
spl147 wrote: Thu Mar 21, 2019 8:13 pm
I see, thanks. I'd thought the standard 1.01 fw was going to be supported eventually
spl147
Post by spl147 »
Official 1.00 is supported.
Flashing the patched firmware takes like 2 mins. And works perfectly!
I flashed my BU40N (v.1.02) and my WH16NS60 (v.1.01)with MK patched firmware
Post by SamuriHL »
I'm using NS60 1.01 MK, as well. Works great.
jonghotti
Post by jonghotti »
Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
So can anyone verify that with this interim MK firmware the BP60NB10 drive now works?
Is flashing over the USB port now possible?
spl147
Post by spl147 »
jonghotti wrote:Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
I flashed both my BU40N and my WH16NS60 over usb, using vantec enclosures
Japio
Post by Japio »
jonghotti wrote: Fri Mar 22, 2019 1:54 pm Remember what really matters with a true "Official" drive is a the presence of the UltraHD Blu Ray logo.
That is something I would also like to know.
Still waiting for a response from support, for a long time now.
Try it and see. I have a feeling the flashers won't like the enclosure though. Still worth a try. It will either work or it won't.
