UHD drives
Locked
tamorgen
Re: UHD drives
#601 Post by tamorgen » Wed Mar 20, 2019 9:57 pm
mike admin wrote: Wed Dec 06, 2017 6:18 pm The absolute best “UHD-friendly” drive at the moment is ASUS BW-16* series.
Is this still accurate for the "best" UHD-friendly drive? The post is a couple of years old, and I'm not sure if it's been edited since then. I have a LG WH16NS40 with Firmware Revision 1.02, and it only works some of the time. I'd say i've been able to rip 1/3 to 1/2 of my UHD discs. Most of the others get part way through, and start throwing errors. When I look up the error, it tells me most of the time the drive is going bad. It works fine on regular blu-ray and dvd, but it has problems with UHD discs, brand new, straight out of the box.
Thanks for any advice.
Re: UHD drives
#602 Post by SamuriHL » Thu Mar 21, 2019 1:06 am
I have both of the "best" UHD drives IMO. The ASUS with MK 3.10 on it is absolutely awesome. And the LG NS60 with MK 1.01 on it is also a beast, but, not "friendly". You can flash the ASUS firmware on an NS60 if you want, but, if you're just looking for a friendly drive that works in everything, the ASUS drive is excellent IMO.
bigpoppa7565
Re: UHD drives
#603 Post by bigpoppa7565 » Thu Mar 21, 2019 3:20 am
Please try MK version of the firmware it a lot better then DE version. LG WH16NS60
It been reading all UHD disc and disc error issues
viewtopic.php?f=19&t=19113
ipkha
Re: UHD drives
#604 Post by ipkha » Fri Mar 22, 2019 12:07 am
bigpoppa7565 wrote: Thu Mar 21, 2019 3:20 am Please try MK version of the firmware it a lot better then DE version. LG WH16NS60
Are you saying the MK firmware is reading the discs better? With less errors then the DE or official firmware? Your post is slightly unclear.
jonghotti
Re: UHD drives
#605 Post by jonghotti » Fri Mar 22, 2019 11:23 am
tamorgen wrote: Wed Mar 20, 2019 9:57 pm
I've been using the software now for a year and those log messages have meant dirty disc the entire time. Ignore that part about the drive failing, total BS.
Chasetheace
Re: UHD drives
#606 Post by Chasetheace » Sat Mar 23, 2019 12:19 am
topprospect wrote: Sun Dec 24, 2017 12:52 pm
mike admin wrote:TLDR: Buy internal or external ASUS BW-16* drive and do not update its firmware.
Warning: ASUS BW-16D1X-U (external USB3 model) does not read UHD discs AT ALL. In fact, when I opened up the enclosure, I found that the drive is actually a Pioneer BDR-209MBK. So don't buy just any BW-16* drive, make sure the specific model number is on mike's list in the OP.
However, if you remove that Pioneer drive from the ASUS BE-16D1X-U sled and replace it with an ASUS BW-16D1HT, ripping UHD discs over USB3 works great. I'm using MakeMKV 1.10.8 and BW-16D1HT firmware 3.01. Works in Mac and PC.
Same with me, what did you do with new pioneer drive? Did you sell it and how much h is it worth? Cause I have exact same one too from external BW-16D1H-U that I Purchased.
I was really shocked to think that ASUS was actually using Pioneer drives in there equipment that they are selling
bigpoppa7565
Re: UHD drives
#607 Post by bigpoppa7565 » Sat Mar 23, 2019 12:27 am
ipkha wrote: Fri Mar 22, 2019 12:07 am
Sorry I'm be clearer, I have notice better performance (reads) with MK firmware then with DE version. That all the discs that where not working are working now. Like MI Fallout and SW Solo that wouldn't read in that drive. Both read fine in the LG WH16NS40.
jonghotti
Re: UHD drives
#608 Post by jonghotti » Sun Mar 24, 2019 2:24 am
No disc read issues using the stock 1.00 in the WH16NS60.
VDubb
Re: UHD drives
#609 Post by VDubb » Fri Mar 29, 2019 2:36 am
I currently have a WH16NS40 1.02 drive, but I want to get a second drive for backup.
Should I get another WH16NS40 or get a WH16NS60? Does one drive give a better quality rip than the other? Is one faster than the the other?
Thanks for any recommendations.
Re: UHD drives
#610 Post by MartyMcNuts » Fri Mar 29, 2019 10:55 pm
VDubb wrote: Fri Mar 29, 2019 2:36 am I currently have a WH16NS40 1.02 drive, but I want to get a second drive for backup.
Since you already have a friendly drive, I would recommend the WH16NS60 Official UHD drive as the one to get. It is fast (if not the fastest) drive available for ripping UHD and is compatible with MakeMKV.
mister_eff
Re: UHD drives
#611 Post by mister_eff » Sat Mar 30, 2019 9:11 pm
Chasetheace wrote: Sat Mar 23, 2019 12:19 am
How do you open up the enclosure to replace the internal drive? Thanks
Chasetheace
Re: UHD drives
#612 Post by Chasetheace » Sun Mar 31, 2019 12:15 am
Underneath the drive there is sticky rubber feet. At the rear were the power plugs in gently use a small flat head screw driver and prise the flat rubber support feet away from the base of the drive. Store them with the sicky side up so no dust or dirt gets on them and they will stick back on quite easy.
You will see underneath where the rubber feet was, 2 small star head screws which can be removed with a small star head screw driver.
When you have done this the top of the drive can be prised off with a plastic tool or something like a credit card. When you get it started work your way around and it will snap all the clips out which holds it together.
Be very careful when pullings aparts as there is some fine cables that are stuck down the cables can be gently pulled away from the top of the drive. Do not you steel screw driver to prise apart or you will damage and mark casing.
Then at the back off the drive there is a metal sheild that needs to be taken off at this stage you can prise tge sata connector of the pioneer drive and fit BW-16D1HT drive.
Thank you, 😊
mister_eff
Re: UHD drives
#613 Post by mister_eff » Mon Apr 01, 2019 7:57 am
Chasetheace wrote: Sun Mar 31, 2019 12:15 am Underneath the drive there is sticky rubber feet. At the rear were the power plugs in gently use a small flat head screw driver and prise the flat rubber support feet away from the base of the drive. Store them with the sicky side up so no dust or dirt gets on them and they will stick back on quite easy.
Thank you, 😊
Thank you for the detailed instructions! I replaced the drive, added the new firmware thanks to this link:
https://www.makemkv.com/forum/viewtopic ... 16&t=18933
A few hours later, I'm streaming the first episode of Planet Earth II with Kodi and it looks amazing! Thanks
Chasetheace
BP55EB40 MK Firmware
#614 Post by Chasetheace » Sun Apr 07, 2019 6:49 pm
First of apologises for posting in wrong section earlier and double posting. I tried to delete but realized I posted in wrong section. I have drive Slim Portable LG-BP55EB40 SVC Code EB40
Firmware Ver 1.00 is this drive upgrade to UHD friendly LibreDrive
Can anyone tell me if I use new flasher will it damage this drive. Under the MK directory there is firmware for BP55EB40-NB50?
PRAGMA
Re: UHD drives
#615 Post by PRAGMA » Wed Apr 10, 2019 1:31 pm
Guys can yall just update me, will this work:
https://www.amazon.co.uk/gp/product/B00Z1LXAJG
And if it does work, is it more or less just plug and play using MakeMKV?
Locked
