Hi All-
Apologies if this is covered elsewhere...I tried to search for relevant terms and didn't see anything obvious.
I use MacOS on a MacBook Pro and MacMini. Both those use slimline laptop drives. Are there any MacOS friendly UHD drives that are either:
1) slimline that can retrofit into either of the above cases, or
2) USB3 compatible that I can use as a standalone
yw.
UHD USB drives (or laptop slimline?)
Re: UHD USB drives (or laptop slimline?)
The BU40N is a 9.5mm slim UHD drive.YouWho wrote: Wed Mar 20, 2019 7:54 pm Hi All-
yw.
A good external option is the Archgon MD-8107S-U3-UHD. The drive inside the Archgon is also a BU40N.
You can find them both on Amazon.
I've been tempted to splurge on the Pioneer BDR-XD07J UHD Blu-Ray drive, with an USB Type-C connector which looks as slim as it can get and an absolute beast for reading media on the go. However, I read that Pioneer drives are a poor choice for MakeMKV.
yes they are a poor choice for now unless your pc meets the powerdvd requirements and you just want to watch themVillodre wrote: Sat Mar 23, 2019 1:35 am I've been tempted to splurge on the Pioneer BDR-XD07J UHD Blu-Ray drive, with an USB Type-C connector which looks as slim as it can get and an absolute beast for reading media on the go. However, I read that Pioneer drives are a poor choice for MakeMKV.
Currently Pioneer drives are not good if you want to back-up your UHD discs. No ripping software is compatible with them. This is why we always recommend the LG or ASUS drives.Villodre wrote: Sat Mar 23, 2019 1:35 am I've been tempted to splurge on the Pioneer BDR-XD07J UHD Blu-Ray drive, with an USB Type-C connector which looks as slim as it can get and an absolute beast for reading media on the go. However, I read that Pioneer drives are a poor choice for MakeMKV.
BU40N in Vantec enclosure. You want one of these and should email me to get one. alexcoluzzi32@gmail.com
I now return to finishing off the units owed to people who have been waiting patiently.
Oh, well, I'm in the EU so I hardly think it would worth it, but I did see your units here in the forum and I think they're awesome.jonghotti wrote: Sun Mar 24, 2019 2:29 am BU40N in Vantec enclosure. You want one of these and should email me to get one. alexcoluzzi32@gmail.com
Shipping to the EU is only $24 USD
Hi again-
Sorry, I was on holidays and just got this reply (thanks to MartyMc). I ordered the Archgon external so I could pass it between my MBP and MB Air as needed. Do I need to deal with firmware upgrade or downgrade on this unit? If so, is there a MACOS option for that or do I need to hijack my wife's Win10 worktop?
thanks again!
yw.
thanks again!
yw.
MartyMcNuts wrote: Thu Mar 21, 2019 12:24 amThe BU40N is a 9.5mm slim UHD drive.YouWho wrote: Wed Mar 20, 2019 7:54 pm Hi All-
yw.
it may need a downgrade the Archgon i got had 1.01 and needed to be downgraded if you have a win 10 pc in the house it will be easier then setting up a vm of windows on mac thats the only way on mac for now.YouWho wrote: Tue Jul 30, 2019 12:01 am Hi again-
thanks again!
yw.
You will most likely have to downgrade the firmware and yes, the quickest and easiest way is using a windows machine.YouWho wrote: Tue Jul 30, 2019 12:01 am Hi again-
thanks again!
yw.
yw.
Gotcha. Assuming that the tutorials cover the how-to's in the root post of this forum (?). As a former UNIX hacker, should i assume there is now straight forward command line or otherwise option on MacOS's bastard child *NIX-esque system?MartyMcNuts wrote: Tue Jul 30, 2019 12:15 amYou will most likely have to downgrade the firmware and yes, the quickest and easiest way is using a windows machine.YouWho wrote: Tue Jul 30, 2019 12:01 am Hi again-
thanks again!
yw.
