Samsung BD-P4600
ccc38941
Samsung BD-P4600
Post by ccc38941 » Mon Aug 23, 2010 9:01 am
Audio playback: ok
Video playback: failed
Mkv not supported ( the one made whit makemkv )
MakeMKV log info:
MakeMKV v1.5.8 win(x64-release) started
Complex multiplex encountered - 8 cells and 4067 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (8 cell(s), 1:04:56)
Operation sucessfully completed
the operation take max 15min
Convered DvD to mkv
The BD-P4600 is updated
When it is working fully i will buy the program
http://hd.engadget.com/2009/07/16/samsu ... 00-review/
I think i found the problom, DvDs are encoded whit mpeg and the ones i already have are in avc, so i have to reencode the dvd and then use makeMKV, have tryed Nero recode 2010 witch is bught, but it dont work
the way i think: If i like it i buy the BD, if not i even dont wanner DL the disc to see if i like it ( youtube -> prewive of the movie )
So mkv`s are just a backup security way, so there dont get scratched, movie like ( metroplice which is on dvd and avtar in HD and 3D ( yep i have a 200 Hz ))
setarip_old
Re: Samsung BD-P4600
Post by setarip_old » Mon Aug 23, 2010 8:55 pm
Hi!
Then the "ones you have" are NOT DVDs...
[/color]
ccc38941
Post by ccc38941 » Tue Aug 24, 2010 4:53 am
So dvds cant be played as Mkv but as dvds. as mkv there only takes ~2Gb but i guess it is cus it is a stripped version, but what i can see is it the codex (mpeg/AVC) that is the probom atm, unless you have an idear
Icanseestars
Post by Icanseestars » Tue Aug 24, 2010 2:02 pm
ccc38941 wrote:So dvds cant be played as Mkv but as dvds. as mkv there only takes ~2Gb but i guess it is cus it is a stripped version, but what i can see is it the codex (mpeg/AVC) that is the probom atm, unless you have an idear
DVD's do not use the MPEG-4 AVC codec.
DVD's use MPEG-2 video.
MakeMKV does not covert video, it rips it as is.
ccc38941
Post by ccc38941 » Tue Aug 24, 2010 6:08 pm
I know, but why ake it if there is a problom whit the support for playback
skittle
Post by skittle » Tue Aug 24, 2010 6:19 pm
Because only a few (hardware) players do not support it (mpeg2 in mkv), and only because the manufacturer does not want to support it.
My advice is to get a real hardware player that supports everything like a popcornhour, or live with the limitations of your current hardware.
