Advice
Green Arrow
Advice
Post by Green Arrow »
Hi, I'm new to the group, anyway I'm here to advise you eventually. I have noticed that in the program there is only a preference for audio language and subtitled language, and I believe that it is necessary to add the other possibilities which however will not be predefined but will be selected as soon as a disc or folder is examined (perhaps for advanced users). Another thing, integrate the homonymous BDInfo that can produce the file in txt of the disk examination.
Re: Advice
It seems you're offering advice on how to change the program, when you really have not USED the existing features of the program.
You can elect to NOT chose a preferred language, and audio/subtitle choices selected will reflect all languages in the source.
If you need a text file of the disk information, the command line version will generate it, for use in batch processing.
Green Arrow
Re: Advice
I forgot, in addition to what I said, I was thinking: wouldn't it be nice to have less graphic graphics? have the possibility to see what you are about to rip on an integrated video player? maybe create a more normal version for renaming files in mkv ... es: Star_Wars_Revenge_of_the_Sith.title...mkv oppure Star_Trek_Tos_Season_1_Disc_4.title....mkv
Simple and direct
