sumvision
#166 Post by sumvision » Sun Mar 17, 2019 9:29 pm
Does anybody know if you can adjust the audio sync? I got the holy grail but it's out of sync :cry:
Dantrigger
#167 Post by Dantrigger » Mon Mar 18, 2019 7:13 pm
How di you manage to get Dolby Atmos? Did you re-encode the truehd track?
Grencola
#168 Post by Grencola » Mon Mar 18, 2019 11:41 pm
sumvision wrote: Sun Mar 17, 2019 9:29 pm Does anybody know if you can adjust the audio sync? I got the holy grail but it's out of sync :cry:
what hardware are you running? depending on the models this setting can be found on TV's, BD Players, and AVRs. you probably have one of those 3 things that can do it :)
Grencola
#169 Post by Grencola » Tue Mar 19, 2019 2:10 am
So after enough testing, I can now safely say the dv mp4s made from mkvs DO infact work just fine :) i've ran my program on like 10 of them and they all show dv and look and play amazing, with better contrast in the darker scenes that hdr10 misses. I'll update my app and take mkv out of testing and into full on good to go mode :) yay!
I've also added elapsed time so you know how long it took when it finishes and bumped it to version 2.0 since I don't think I can add any more features with the knowledge i have lol.
DV-MP4-Maker v2.0: https://bit.ly/2WbHZR0
sumvision
#170 Post by sumvision » Tue Mar 19, 2019 2:59 pm
Dantrigger wrote: Mon Mar 18, 2019 7:13 pm How di you manage to get Dolby Atmos? Did you re-encode the truehd track?
No unfortunately that isn't possible yet without Dolby Media producer suite :cry: It's only a lossy Atmos track from a WEB-DL but better than no Atmos at all I guess.
Grencola wrote: Mon Mar 18, 2019 11:41 pm what hardware are you running? depending on the models this setting can be found on TV's, BD Players, and AVRs. you probably have one of those 3 things that can do it :)
After a lot of experimenting and many muxes I managed to get it to sync up straight out of mp4muxer :D
Grencola
#171 Post by Grencola » Tue Mar 19, 2019 5:05 pm
sumvision wrote: Tue Mar 19, 2019 2:59 pm After a lot of experimenting and many muxes I managed to get it to sync up straight out of mp4muxer :D
haha ok cool
timason
#172 Post by timason » Thu Mar 21, 2019 6:19 am
Is there a way to play those files on Windows 10 as well?
I use mostly the OLED to play my files but sometimes I will use the PC to play the sames files for my other monitor/ different TV.
I also use this to add subtitles and sync them up.
MPC-HC doesn't play those mp4 mux.
Thanks.
Ray80
#173 Post by Ray80 » Thu Mar 21, 2019 3:04 pm
For the first time, I'm enjoying DV films, and it is awesome. Thank you!
I have a question: is it possible to add a second audio track to the mp4 file that can be played in the LG TVs? I have used mp4muxer and the new track can be played in Windows with VLC (without dolby vision of course), but my LG C7's internal player/plex can't play the second audio track (it can be selected, but it always plays the first track). Maybe I'm doing something wrong with the remuxing.
Thanks again!
ripem
#174 Post by ripem » Thu Mar 21, 2019 4:55 pm
i dont know if this is what people are tring to do but i use MKVToolNix it shows both videos and saves every thing to mkv it plays DV and ATMOS on my 4k bluray player with usb stick just wish it could be compressed to like 10gig
sumvision
#175 Post by sumvision » Thu Mar 21, 2019 10:20 pm
ripem wrote: Thu Mar 21, 2019 4:55 pm i dont know if this is what people are tring to do but i use MKVToolNix it shows both videos and saves every thing to mkv it plays DV and ATMOS on my 4k bluray player with usb stick just wish it could be compressed to like 10gig
Your Blu-ray player is lying to you. As soon as you put DoVi anywhere near MKV it does not work. Even single layer DoVi files don't work with MKV.
Grencola
#176 Post by Grencola » Thu Mar 21, 2019 10:32 pm
you mean hdr10 and atmos? ;) dolby vision doesn't work from mkv. only m2ts / ts / mp4
ripem
#177 Post by ripem » Fri Mar 22, 2019 2:20 am
Grencola wrote: Thu Mar 21, 2019 10:32 pm
i stand corrected i just tried with mkv it fault to hdr it must have been a m2ts :oops: :oops: :oops: :oops:
Synerge
#178 Post by Synerge » Fri Mar 22, 2019 6:40 am
Grencola wrote: Tue Mar 19, 2019 2:10 am So after enough testing, I can now safely say the dv mp4s made from mkvs DO infact work just fine :) i've ran my program on like 10 of them and they all show dv and look and play amazing, with better contrast in the darker scenes that hdr10 misses. I'll update my app and take mkv out of testing and into full on good to go mode :) yay!
I have a LG 2016 with dolby vision
I tried first with the normal way. First with TS Muxer and then MP4Muxer. In the pc I cannot open that file, gives critical error. But on the LG works fine, showing the dolby vision notification
I tried then with your system. I can open the file in the PC (looks like normal hdr), but the tv just wont play it.
Not sure where the problem is, maybe in the track muxer or in the mp4muxer if you changed something on there
Grencola
#179 Post by Grencola » Fri Mar 22, 2019 7:24 pm
Synerge wrote: Fri Mar 22, 2019 6:40 am I have a LG 2016 with dolby vision
crazy I heard the b6/c6 didn't work with these mp4s in DV, just the 7/8's. good on you though if you got it to work. I can't test that. also my script uses eac3to instead of tsmuxer as it was far more stable and seemed to demux files better. you can snag it here if you want: https://www.videohelp.com/software/eac3to
it should work fine as me and many others have made scores of mp4s now and they're working great, using both tsmuxer and eac3to.
Synerge
#180 Post by Synerge » Fri Mar 22, 2019 9:45 pm
Grencola wrote: Fri Mar 22, 2019 7:24 pm
It may be possible that is the movie that failsn and not the process. I didnt tried with the same movie as before because it takes way too long
BTW, I dont have an oled, my tv is a super uhd from lg, uh7700, with dolby vision
Also, can the speed of the process be accelerated by moving the files to a ssd? or is it exclusively done by cpu power?
