Asus BW-16D1HT 3.03
mfraz74
Asus BW-16D1HT 3.03
Post by mfraz74 »
Finally got round to installing my new Asus BW-16D1HT drive today, I presume the 3.03 is the firmware version?
Harware support: Yes
Firmware support: No
Firmware version: 3.03
When I start to rip a blu-ray, I see this in the logs:
MakeMKV v1.14.3 linux(x64-release) started
LibreDrive firmware support is not yet available for this drive (id=AFD1721A73BF)
I am running Ubuntu 18.10, is there any chance this drive will be able to rip UHDs?
Re: Asus BW-16D1HT 3.03
Post by SamuriHL »
Yes, but, you will need to either downgrade it to 3.02 with a downgrade enabled firmware bin or use the MK 3.03 version Mike has created. See here:
viewtopic.php?f=19&t=19113
Also it will need to be flashed in Windows. A WinPE usb stick will suffice.
mfraz74
Post by mfraz74 »
What software other than WinPE do I need to upgrade to MK 3.03?
mfraz74 wrote:
Sun Mar 17, 2019 9:16 pm
The ASUS windows flasher + firmware
viewtopic.php?f=16&t=18933
and/or the MK firmware (see previous post from SamuriHL) if you want to stay on 3.03 firmware.
Post by SamuriHL »
Right, in either case as Marty said you need to use a patched Windows flasher and the firmware bin in a Windows environment. I've seen a Mac user do it in a Windows VM under VirtualBox so that's an option, too. Whatever is easiest to get a Windows environment up and running long enough to run the flasher, select the drive, select the firmware bin file, and then flash it. I've left my drive on the MK 3.03 version and that has all functionality (UHD friendly) completely restored. So for this drive, that's a very decent option.
WARNING: DO NOT upgrade the drive to the new 3.10 firmware that ASUS just released. Doing so will (for now) remove the ability to downgrade and remove LibreDrive compatibility. Until Mike has a chance to patch that firmware, but, there's ZERO benefit in upgrading to it anyway. Stick with the MK 3.03 or DE 3.02 and you'll be good to go.
John310
Post by John310 »
Hi
Im thinking about buying this drive for my pc tower. Is the Asus BW-16D1HT a good reliable drive and is it a compatible LibreDrive?
John310
Post by SamuriHL »
As long as you have a proper firmware on the drive, then yes it's LibreDrive compatible. And yes, it's a very good drive. I've been using mine for over a year and some change now. It works very well.
John310
Post by John310 »
SamuriHL wrote:
Mon Mar 18, 2019 4:04 pm
if I get go ahead with this drive can the firmware be changed to maker it LibreDrive Compatible? is it a solid drive for ripping as well as burning DVD and Blu-Rays?
Thank
John310
Post by SamuriHL »
I'm going to give a caveat answer to your question. ASSUMING it comes with 3.03 then making it LibreDrive compatible is fairly academic at this point. I'd use the patched Windows flasher and flash Mike's MK 3.03 on it and be done. My caveat is that if it comes with 3.10 that ASUS just released, it may take a bit of time before Mike can release an MK version because that is not downgrade enabled so you can't go back to 3.02 or MK 3.03 if it ships with that version. That being said, that version just got released in the past week or so. Most likely you'll end up with a drive that has 3.03 on it and you should be good to go. As for your other questions, yes, it's very solid in ripping and I've had no issues with the BD-R/E's I've burned on it but I don't often burn media....and I use Verbatim media from Japan when I do.
John310
Post by John310 »
SamuriHL wrote:
Mon Mar 18, 2019 5:41 pm
Thanks for all the information. it sounds like this Drive will be useful to me so I have now ordered it. I will see how it goes when It arrives.
Many Thanks again to everyone
John310
Post by SamuriHL »
Great, good luck! Let us know if you need any assistance when you get it.
computermoose44
Post by computermoose44 »
Hey Guys,
I am having similar trouble as the OP, same drive, same firmware. I first tried flashing with the new MK 3.03 firmware. MakeMKV still says
MakeMKV v1.14.3 win(x64-release) started
Saved SD dump file as C:\Users\School/.MakeMKV/dump_SD_BEBB0710929BC4F2D5A3.tgz
Downloading latest SDF to C:\Users\School/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
Downloading latest HK to C:\Users\School/.MakeMKV ...
Saved AACS dump file as C:\Users\School/.MakeMKV/MKB20_v61_Fantastic_Beasts_and_Where_to_Find_Them_8C29.tgz
I also tried to downgrade to 3.02 DE as suggested by the forums.
Same result. Any ideas?
computermoose44 wrote:
Mon Mar 18, 2019 11:06 pm
Hey Guys,
You need to make sure that "Allow contacting web server for updates" is enabled (ticked) in Preferences (General tab).
Post by SamuriHL »
And that you have no firewall rules blocking it. We've seen both issues lately.
mfraz74
Post by mfraz74 »
MartyMcNuts wrote:
Sun Mar 17, 2019 9:50 pm
Thought I'd have a go first at running the software under Wine, but I get:
I can't issue command through SPTI
Any idea what this means?
