AV sync issue for one episode of TV series
Holiday45
#1 Post by Holiday45 » Fri Jan 18, 2019 5:29 am
I've ripped a 10 DVD set of the TV series The Virginian and all episodes but one worked just fine. After getting errors on the disc I returned the set and received a new one. I get the same error on the new set. I'm a newbie at this and I could really use someone's thoughts on how to fix this issue. Thanks!
Title #1 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 was added (4 cell(s), 1:15:17)
Title #4 was added (3 cell(s), 0:33:49)
Title #5 was added (4 cell(s), 1:15:02)
Saving 1 titles into directory E:/TV Shows/The Virginian/Season 01
DEBUG: Code 149430 at }v9S<}>On\hMdk[orLS,:213143002
DEBUG: Code 0 at }v9S<}>On\hMdk[orLS,:29404050
DEBUG: Code 0 at Si0V5Sd:mgl|*kGOu<s]#:213136608
DEBUG: Code 0 at '(?Zq2.A;"@kC(Q\:29395908
DEBUG: Code 0 at \C@4>BUjX4FWQW0Tk:213132698
DEBUG: Code 0 at \C@4>BUjX4FWQW0Tk:213132146
DEBUG: Code 0 at \C@4>BUjX4FWQW0Tk:29393769
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
AV synchronization issues were found in file 'E:/TV Shows/The Virginian/Season 01/title_t01.mkv' (title #2)
AV sync issue in stream 0 at 0:42:20.104 : video frame timecode differs by +2492.99s
Failed to save title 1 to file E:/TV Shows/The Virginian/Season 01/title_t01.mkv
0 titles saved, 1 failed
haemaker
Re: AV sync issue for one episode of TV series
#2 Post by haemaker » Sun Mar 17, 2019 5:13 am
Try this:
Open the disk manually, and just put "4" in the title selection box. If that works, do the same for "5".
I do not know why, but sometimes that makes a difference.
