Grencola
#151 Post by Grencola » Sun Mar 03, 2019 6:30 am
for those who care, I've updated my program to be smarter. I combined the two apps into one, and named it DV-MP4-Maker. It now checks for the file type (m2ts or mkv) in the chosen directory and runs the required script.
I added support for smb/network shares (although mapping the network drive works fine), keeping the original filename intact, and it also checks the file for a DV layer and if no track is found it prompts you and exits instead of trying anyway with crazy errors.
link: https://bit.ly/2F9tSEN
cheers! :)
edit: for those who don't trust simple winrar sfx files, here's the source code:
@echo off
for %%a in ("*.m2ts") do @echo %%~na> filename.txt
ren *.m2ts Movie.m2ts
@echo M2TS file found! Extracting tracks, please wait (approx. 30 mins)...
eac3to.exe Movie.m2ts 1: bl.hevc 2: el.hevc 3: audio.ac3 -core -640
@echo Muxing tracks to MP4, please wait (approx. 45 mins)...
mp4muxer_64bits.exe --dv-profile 7 -i bl.hevc -i el.hevc -i audio.ac3 --media-lang eng -o DV-Movie.mp4
set /p texte=< filename.txt
ren Movie.m2ts %texte%.m2ts
ren DV-Movie.mp4 %texte%.Dolby.Vision.mp4
@echo Cleaning up temp files... Done!
echo y | del avcodec-54.dll del avutil-52.dll del hdcd.dll del HookSurcode.dll del libaften.dll del libdcadec.dll del libFLAC.dll del libMatrix.dll del libSsrc.dll del msvcr100.dll del r8b.dll del mkv.cmd del filename.txt del *log.txt eac3to.exe del mp4muxer_64bits.exe del bl.hevc del el.hevc del audio.ac3
@echo Process Complete! Enjoy :)
pause
del m2ts.cmd
paste that into a txt file and rename it m2ts.cmd then download eac3to and mp4muxer.exe and put their files along with m2ts.cmd all into the same folder as your movie and run m2ts.cmd.
my winrar self-extracting (sfx) file automatically runs the .cmd file as soon as it puts the files needed into your movie folder. but it is an exe file so I guess it sketchy? :p
spl147
#152 Post by spl147 » Sun Mar 10, 2019 12:20 pm
For any of you that want to watch Dolby Vision Correctly, see this thread!
viewtopic.php?f=6&t=19035
annisman
#153 Post by annisman » Mon Mar 11, 2019 5:11 am
Grencola wrote: Sun Mar 03, 2019 6:30 am for those who care, I've updated my program to be smarter. I combined the two apps into one, and named it DV-MP4-Maker. It now checks for the file type (m2ts or mkv) in the chosen directory and runs the required script.
link: https://bit.ly/2NOulA9
cheers! :)
@echo off
pause
del m2ts.cmd
Hey Gren,
I have a ton of ripped UHd's in mkv format, unless I'm reading what you wrote wrong... I can just use your application to direct it to the mkv file and it will convert it to use DV ? Is that all there is to it ?
Grencola
#154 Post by Grencola » Mon Mar 11, 2019 7:37 pm
annisman wrote: Mon Mar 11, 2019 5:11 am Hey Gren,
I have a ton of ripped UHD's in mkv format, unless I'm reading what you wrote wrong... I can just use your application to direct it to the mkv file and it will convert it to use DV ? Is that all there is to it ?
that's it, yeah. but mkv is purely for testing purposes right now, I almost shouldn't even allow it until I know for sure how they are. some people claim they work fine, others say the colors get messed up. mine have been hit and miss as well. also the mkv has to be the full remux from a movie in dolby vision with a secondary dv video track.
m2ts files, however, work flawlessly.
If you have more time than I, perhaps you could make a shwack of mp4s from your mkv's and let us know how they look? :)
annisman
#155 Post by annisman » Tue Mar 12, 2019 12:03 am
Grencola wrote: Mon Mar 11, 2019 7:37 pm
Can you please explain what this means ? Does this mean I will need to re rip my MKV in some new way that it will work with your program ?
Grencola
#156 Post by Grencola » Tue Mar 12, 2019 1:07 am
annisman wrote: Tue Mar 12, 2019 12:03 am Can you please explain what this means ? Does this mean I will need to re rip my MKV in some new way that it will work with your program ?
remuxing is basically just a fancy term for a container change. an mkv remux means it's the original uhd-bd that has that has changed from avchd (m2ts) to mkv. the video / audio tracks within are left untouched whereby no compression / modifying has been done.
but like I said, since mkv to mp4 is just for testing out dv, any future backups you make of a uhd-bd with dolby vision should be the original m2ts file you find in the bdmv/streams folder if you wish to make a DV mp4 properly. otherwise mkv's work great for hdr10 and can have much better audio than mp4's.
Since it sounds like you've already ripped a bunch of your discs to mkv, if you want to help test you can always try my program with some of them and let me know how it goes. just thought I'd warn you :)
Jhoopes517
#157 Post by Jhoopes517 » Wed Mar 13, 2019 1:44 am
The main thing you really need to take from this is that the MKV that you are trying to convert to have the Dolby Vision metadata will need to have both video tracks. You can check this by checking the mkv's mediainfo. If you have both video tracks, then converting it should be okay to do. Otherwise, obtaining the .m2ts from the UHD Blu and converting that will be better.
Grencola
#158 Post by Grencola » Wed Mar 13, 2019 2:38 am
Jhoopes517 wrote: Wed Mar 13, 2019 1:44 am The main thing you really need to take from this is that the MKV that you are trying to convert to have the Dolby Vision metadata will need to have both video tracks. You can check this by checking the mkv's mediainfo. If you have both video tracks, then converting it should be okay to do. Otherwise, obtaining the .m2ts from the UHD Blu and converting that will be better.
^^^ What he said ^^^
Jhoopes517, have you tried an mkv to mp4 yet? if so how did it look?
Metallikahn
#159 Post by Metallikahn » Wed Mar 13, 2019 6:58 pm
So I read through this thread and I'm a bit confused. Just want to confirm a few points.
1.) This process creates an MP4 container file that contains all the main files just like we would rip when making an MKV?
2.) The DV layer is converted (or whatever) into a 10 bit layer vs. the original 12 bit?
3.) The MP4 requires the Lossless 7.1 audio track (Atmos/DTS-X) to be converted to a lossy format without the Atmos metadata?
I've got a number of DV uhd's and I thought I'd toy with this a bit to see how well it works. I'm currently playing my MKV's over DLNA from an Emby server to an Oppo203 and then to an LG OLED B7a. Right now, DV is a bit of a novelty for me since I tend to prefer the way HDR looks on my OLED (I like the technicolor picture mode I have available for HDR content. DV content doesn't give me that option and the black tend to look a lot more grey on my display without it). Between Dolby Vision and Atmos, I'd rather have the Atmos atm, so the loss of it in this process would probably be a deal breaker for me.
I'm currently folder ripping Valerian to give it a try. Just wanted to make sure I was clear on what to expect.
TheShoe
#160 Post by TheShoe » Wed Mar 13, 2019 10:27 pm
what are you all using for playback?
most (all?) software players i don’t think would support DV playback.
Grencola
#161 Post by Grencola » Thu Mar 14, 2019 2:02 am
Metallikahn wrote: Wed Mar 13, 2019 6:58 pm So I read through this thread and I'm a bit confused. Just want to confirm a few points.
that's correct. once you rip the full valerian disc contents (not mkv) go into its dir and put the largest .m2ts file from \bdmv\streams\ into its own folder. then run my app and point it to that folder and click install. wait about 1h15m ish. that's it. you'll be able to play the new mp4 directly from your TV's usb port via usb exfat hdd, or with the plex app (recommended for better gui) right on your tv streaming from your computer (direct play / direct stream on). both should be in DV and look just like playing the disc on your oppo. the audio will be downmixed to dd ac3 5.1. I'm not sure about about emby but give it a go for sure and let me know.
this is all obviously just a fun experiment though as it's a pointless process for you since you can just take a uhd disc and pop it in your udp-203 and get DV / hd-audio, rather than put it into your computer to rip and convert and then play with worse audio :p or if you were to rip it to the full folder structure of the disc, that too can be played in your oppo in DV / hd-audio :p
this is for people who can't afford an Oppo (especially now, my goodness). they either own an LG or Vizio TV with a non-atmos AVR. so adding DV while losing the atmos they never had anyway is a nice step up for a lot of people :)
Grencola
#162 Post by Grencola » Thu Mar 14, 2019 2:07 am
TheShoe wrote: Wed Mar 13, 2019 10:27 pm what are you all using for playback?
these mp4's can be played in DV natively on LG (B7 / B8) and Vizio (m / p series, not pq) TV's via their usb media players. LG TV's have the bonus of plex playing them in DV as well, where the Vizio plex app is only hdr10. not sure about Sony TV's but I think it's a no go.
Metallikahn
#163 Post by Metallikahn » Thu Mar 14, 2019 4:12 pm
Grencola wrote: Thu Mar 14, 2019 2:02 am that's correct. once you rip the full valerian disc contents (not mkv) go into its dir and put the largest .m2ts file from \bdmv\streams\ into its own folder. then run my app and point it to that folder and click install. wait about 1h15m ish. that's it. you'll be able to play the new mp4 directly from your TV's usb port via usb exfat hdd, or with the plex app (recommended for better gui) right on your tv streaming from your computer (direct play / direct stream on). both should be in DV and look just like playing the disc on your oppo. the audio will be downmixed to dd ac3 5.1. I'm not sure about about emby but give it a go for sure and let me know.
I totally get how this is great for everybody that's not using it with a full surround sound setup, but like you said, not a perfect solution for me.
I may have an Oppo, but I rarely put an actual disc in it. I usually use it for troubleshooting when I run into a problematic rip. Emby is a lot like plex, though I like it much better than plex. For me, I have a lot more flexibility and setup/browsing options with Emby and it's much easier to navigate the server interface than Plex. Where I like Plex better is if I'm actually streaming to my ipad/phone/etc...
I haven't even bothered with folder rips for DV yet. To my understanding, a folder rip is basically exactly like using a physical disc? Menus and all, correct? One of my main theater goals is to keep it as streamlined as possible. Browse my collection on the Emby phone app, hit play for a given movie, and the movie (just the movie) starts direct playing via DLNA. Wish Oppo had left their OS open for third party apps. Would be great to browse and play all straight from the remote. On well... :)
I am going to give a few go folder rips a try. I have a handful of atmos movies (seemless branching tracks... Mostly disney) that have lots of audio dropouts. Folder rip might be the best option. I might do the same for select DV discs as well.
Thanks for the feedback! :)
Jhoopes517
#164 Post by Jhoopes517 » Sat Mar 16, 2019 7:10 pm
Grencola wrote: Wed Mar 13, 2019 2:38 am
Nah. Haven't tried. All the files I don't have any mkv's with both video tracks and obtaining the m2ts from the discs is pretty easy imho.
Grencola
#165 Post by Grencola » Sun Mar 17, 2019 3:18 am
Jhoopes517 wrote: Sat Mar 16, 2019 7:10 pm Nah. Haven't tried. All the files I don't have any mkv's with both video tracks and obtaining the m2ts from the discs is pretty easy imho.
fair enough.
