BU40n differences?
BU40n differences?
What are the differences in the BU40n folders in the MK firmware pack?
My BU40n does not have a -x letter
Im assuming i need the BU40n-N, but am not sure
Sent from my iPhone Xs Max using Tapatalk Pro
- Contact:
Re: BU40n differences?
Is any LibreDrive information available for it? If yes, please post everything (except the serial number) and I'll tell you what you have.
If no LibreDrive info on main screen, then do the following: With version 1.14.3 (important!) open any BD disc. Quit MakeMKV, look at log file.
You will see the line that reads like "SDFvxx: HL-DT_ST-xxxxxxxxxx" - this is your drive id, it includes serial number.
Post this string (delete the serial number part).
Drive Informationmike admin wrote: ↑Sat Mar 16, 2019 8:19 pmIs any LibreDrive information available for it? If yes, please post everything (except the serial number) and I'll tell you what you have.
Product: BD-RE BU40N
Revision: 1.00
Serial number:
Firmware date: 2116-12-20 15:28
Highest AACS version: 66
Firmware version: 1.00
SDF v057: HL-DT-ST_BD-RE_BU40N_1.00_211612201528_
lets not forget i think you have already flashed this before so it could have been crossflashed to another model bu40nspl147 wrote: ↑Sat Mar 16, 2019 9:34 pmDrive Informationmike admin wrote: ↑Sat Mar 16, 2019 8:19 pmIs any LibreDrive information available for it? If yes, please post everything (except the serial number) and I'll tell you what you have.
Revision: 1.00
Serial number:
Auto flash kit $40 Email me for one Billycar5924@gmail.com
got it from amazon, it came with 1.01 on itBillycar11 wrote: ↑Sat Mar 16, 2019 10:10 pmlets not forget i think you have already flashed this before so it could have been crossflashed to another model bu40nspl147 wrote: ↑Sat Mar 16, 2019 9:34 pmDrive Informationmike admin wrote: ↑Sat Mar 16, 2019 8:19 pmIs any LibreDrive information available for it? If yes, please post everything (except the serial number) and I'll tell you what you have.
Revision: 1.00
Serial number:
mike probably needs what it said on 1.01 before you flashed it to 1.00
i flashed it with the BU40n-N folder version 1.02, works fineBillycar11 wrote: ↑Sat Mar 16, 2019 10:29 pmmike probably needs what it said on 1.01 before you flashed it to 1.00
- Contact:
Thats what i figured, thanks for the info!
I've owned 50 of these so far and I've yet to see a -X letter.
Are you really gonna ask what firmware works with it? Do some reading man, i alone posted just 6 posts above with the firmware i flashed it to.....
No, I can see what you posted above, but there are several variations of BU40N, eg with and without UHD logo on front, I asked which version you have.
You need to chill out 'man', this is a forum for people to help each other
With and Without the logo make no difference, what matters is the region:Dave77 wrote: ↑Wed Apr 03, 2019 2:32 pmNo, I can see what you posted above, but there are several variations of BU40N, eg with and without UHD logo on front, I asked which version you have.spl147 wrote: ↑Wed Apr 03, 2019 11:20 amAre you really gonna ask what firmware works with it? Do some reading man, i alone posted just 6 posts above with the firmware i flashed it to.....Dave77 wrote: Does your BU40N have the UHD logo on the front? I've just ordered one with the UHD logo, just curious as to what firmware works with it.
You need to chill out 'man', this is a forum for people to help each other![]()
N - USA
R - Taiwan
U - Europe
again ALL this info is in this thread!
im not trying to be a jerk, it's just frustrating when people ask the same questions that have been answered a million times, all because the didnt do and research before posting!
just a FYI mine did have the UHD Logo, and i used the N version as i bought it from amazon in the US.
i had another one without the logo bought from overseas, also flashed with the N version, both work fine!
Cheers. I have searched on the bu40n and from what I've read I should say steer clear of the non UHD labelled model. Nobody sells the uhd model in the UK, I've ordered from the USspl147 wrote: ↑Wed Apr 03, 2019 3:24 pmWith and Without the logo make no difference, what matters is the region:
N - USA
R - Taiwan
U - Europe
