http://www.youtube.com/watch?v=lwRaUebWZps
Example via youtube above.
This issue has gotten better but virtually every blu-ray mkv created with MKV shows these macro blocks when fast forwarding over 4x or rewinding at 2x or more.
In the youtube video I am using XBMC but I have able to reproduce in other players like VLC etc.
Anyone else notice this...
Blocks in FF and REW
setarip_old
Re: Blocks in FF and REW
Hi!
Do you see similar behavior when playing your original source material on the same equipment?
dandirk
I cannot play the source (blu-ray) on the same equipment (no blu ray drive). But VLC does have the same behavior playing the m2ts files off the disk on my PC.
Encoding the mkv with clownBD/eac3to (using fps 24000/1001 aka 23.97...) it still persists but not nearly as bad.
So it is more then likely the media but I have been seeing this in all my rips for the last year. The last time I looked into this eac3to/mkvmerge was significantly better in ff/rew...
Maybe this is normal or the best we can get. I know many people don't use ff/rew anymore, they just do 30sec skips etc...
