Error - End of File Marker
stordoff
#1 Post by stordoff » Wed Mar 06, 2019 9:19 pm
Error 'OS error - The end-of-file marker has been reached. There is no valid data in the file beyond this marker' occurred while reading '\Device\CdRom0' at offset '44313524224'
I've noticed this on a few discs now. The backup (MKV or full disc) appears to complete correctly. Is it an error or something to worry about? It's not entirely clear.
nutcase
Re: Error - End of File Marker
#2 Post by nutcase » Sat Mar 16, 2019 7:18 am
Good Morning, I'm also seeing this error, although my file fails. Before updating to the current version it would just get stuck, now it fails:
Error 'Internal error - Operation result is incorrect (183)' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '2400491520'
Error 'OS error - The end-of-file marker has been reached. There is no valid data in the file beyond this marker' occurred while reading '\Device\CdRom0' at offset '2400491520'
Failed to save title 0 to file C:/Video/XmasAroundTW2018/title_t00.mkv
0 titles saved, 1 failed
It's a home made DVD (my kid's Christmas play) if that helps?
Grauhaar
#3 Post by Grauhaar » Sat Mar 16, 2019 5:19 pm
Maybe the home made Blu-ray is not finished/closed and/or have set the wrong size for the file and now the software requests data beyound the real file size.
Good Luck :)
nutcase
#4 Post by nutcase » Sat Mar 16, 2019 7:49 pm
Thank you - if it has been left open, is it possible to close it?
Grauhaar
#5 Post by Grauhaar » Sun Mar 17, 2019 9:06 am
Never burned a Blu-ray, but on DVDs the creating Hardware (Recorder) or Software must finalize the medium to use it on other components.
Good Luck :)
stordoff
#6 Post by stordoff » Wed Mar 20, 2019 5:14 pm
The errors I'm seeing are on retail-purchased Blu-rays, FWIW
nutcase
#7 Post by nutcase » Sun Apr 28, 2019 1:28 pm
Just to close this one off - in the end I just copied the video file off. Didn't actually need makemkv...
