Is Handbrake not compatible with Passthrough of TrueHD?
mike_mgoblue
#1 Post by mike_mgoblue » Sat Mar 16, 2019 7:30 am
I recently converted two movies from Blu-ray to MKV. Those movies were Event Horizon and Batman Returns. Both of those movies use 24-bit Dolby TrueHD. Both of them turned out fine in their MKV format.
However, when I used Handbrake, I selected "Auto Passthrough." I thought the audio would be identical, just as it normally is with DTS-MA audio files. But, that was not what happened. Instead, the Dolby TrueHD 24-bit Lossless format that has a bitrate of 6912kb/s was showing up at Dolby Digital AC3 and being seen as "Lossy" with a bitrate of only 640kb/s.
Does anyone know why that is? ... It was like this for both Event Horizon and Batman Returns. It appears Handbrake is not compatible with TrueHD.
I also tried "Auto Passthough" with the standard Dolby Digital AC-3 format, and it ended up with 16-bits, Lossy, 640kb/s, which I believe is what it actually uses.
Re: Is Handbrake not compatible with Passthrough of TrueHD?
#2 Post by Woodstock » Sat Mar 16, 2019 10:20 am
This isn't the handbrake support forum. They have their own forum at https://forum.handbrake.fr , and they'll require encode logs for the problematic source files.
I do know that "TrueHD passthru" has been an available option versions put out in the last year.
