LG UH12NS30 Libre Drive - Can It Work ?
tha-tv
Post by tha-tv » Wed Mar 06, 2019 9:38 am
Hi All
First time poster here
I have a LG UH12NS30 with a sticker showing ROM Version 1.03 on it
I have not yet put it in my W10 PC
Will it work as a Libre Drive or do I need to flash the ROM
If I do can anyone point me to a good how to?
I do have a copy of MakeMKV and I did by A licence key for it
(good software needs paid help)
I do hope some on can give me a helping hand
markolarko
Re: LG UH12NS30 Libre Drive - Can It Work ?
Post by markolarko » Thu Mar 07, 2019 11:15 am
Hi
I have the same question of the same drive.
When I launch Makemkv and it starts to read the Bluray this is the message..
MakeMKV v1.14.2 win(x64-release) started
LibreDrive firmware support is not yet available for this drive (id=D1C17F787A5D)
At startup i get this message from MKV..
I have tried searching for the same answer but I have yet to find a clear answer. So if you get a positive reply I will be delighted!
markolarko
Post by markolarko » Thu Mar 07, 2019 11:29 am
Adding to my earlier message. ..
If anybody can help say when or if LibreDrive will / is available I will be eternally grateful.
On loading a dvd I get this message..
Current profile: DVD-ROM
Product: BDDVDRW UH12NS30
Revision: 1.00
Serial number: K9IE42F3328
Firmware date: 2113-06-13 14:57
Bus encryption flags: 16
Highest AACS version: 65
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 1.00
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
Disc Information
Label: DVD_VIDEO
Timestamp: 2005-05-19 19:28:08
Data capacity: 7.95 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
markolarko
Post by markolarko » Thu Mar 07, 2019 11:43 am
Dummy - Response.. Enabling email update when reply posted.
spl147
Post by spl147 » Sat Mar 09, 2019 1:20 pm
tha-tv wrote: Wed Mar 06, 2019 9:38 am Hi All
Does it say NS50 on the label?
i believe support started with the newer NS40 drives, so i would say no. your drive will not read UHD Discs.
tha-tv
Post by tha-tv » Sun Mar 10, 2019 12:14 pm
I have SVC code NS30 so I guess no go then, No probs I hae ordered a new drive from a seller here
tha-tv
Post by tha-tv » Wed Mar 27, 2019 9:13 am
Hi
Sorry to seem think but I cannot see my drive mentioned in page the link points to
