Are my drives supported?
aan3kk
Post by aan3kk »
Hello everyone,
I have these two drives and would like to know if they're supported.
OS device name: E:
Manufacturer: PLEXTOR
Product: BD-R PX-B920SA
Revision: 1.03
Serial number: K158C3E4604
Firmware date: 2009-01-16 12:34:56
Highest AACS version: 31
OS device name: E:
Manufacturer: MATSHITA
Product: BD-MLT UJ272
Revision: 1.02
Serial number: WQ94 820938
Since the Plextor drive is really old (but still rocking) I think I'd prefer the Matshita drive being supported.
Thank you very much! :)
flashback8
Re: Are my drives supported?
Post by flashback8 »
Insert a couple of Blu-Rays and find out for yourself. :) If it's supported, the info will come up eventually. For my Buffalo BRUHD-PU3 (BU10 firmware), LibreDrive didn't kick in for the first disc for some reason but did on the second.
aan3kk
Post by aan3kk »
I need 4K Blu-rays for that, don't I?
No, even opening a DVD should have MakeMKV check your drive. LD isn't a "UHD-only" thing.
planet1
Post by planet1 »
flashback8 wrote:
Thu Mar 14, 2019 9:58 pm
Hello flashback8,
is that drive of yours a UHD-official or "just" a UDH-friendly device?
My Buffalo BRXL-PT6U2VB was briefly tested (LibreDrive line appeared in the log) on the first try but ever since no metioning (right info drive area) or further LibreDrive testings (debug or log) take place :( :
OS device name: F:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN11
Serial number:
Firmware date: 2117-11-20 13:51
Bus encryption flags: 1F
Highest AACS version: 65
Disc Information
Label: SPIDER-MAN_HOMECOMING
Timestamp: 2017-09-19 13:06:01
Data capacity: 41.97 Gb
Disc type: BD-ROM
Number of layers: 2
Regards,
planet1
flashback8
Hi. Sorry about the late reply. It's UHD official. I got it for easy usage when traveling. The BU11 firmware may or may not be supported by LibreDrive. I'm not going to flash in order to find out. :) If somebody has a drive with BU11 already on it and wants to report back, please do.
Anametureenthisiast
Post by Anametureenthisiast »
flashback8 wrote:
Fri Mar 29, 2019 7:15 pm
Hi
Sorry to tell you this but from what I understand if it's am official drive it implements full AACS 2.0 encryption where there's no way around at this time so your drive isn't likely compatible
flashback8
Hi. I actually did plug in my drive eventually. With the BU10 firmware, it's good to go. :) I sent Mike some data to see if there's any way to either revert drives with BU11 (it doesn't work, or so I'm told) or to mod the firmware such that it'll work with LD.
To be clear, drives with BU10 firmware can rip 4K discs. They take awhile to get started but they can do it. BU11 drives can't.
