Current profile: DVD-ROM
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 1.00
Serial number:
Firmware date: 2113-06-14 12:00
Bus encryption flags: 1E
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 1.00
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
Any plan to add support for that drive?
ASUS BC-12D2HT
Re: ASUS BC-12D2HT
Kind of wondering why you're asking? Or are you thinking that the program would say this if the author had no intention of following through?
Re: ASUS BC-12D2HT
Just a fwi don't flash that drive it won't enable libredrive and won't make it uhd friendly it will just make it read no disks
- Contact:
Re: ASUS BC-12D2HT
Now there is one more option available. You can flash 3.01 MK firmware. It won't do magic and make your drive UHD compatible (hardware is not there) but it will make your drive LibreDrive compatible - meaning you will read any BD or DVD disc forever and won't worry about AACS revocations or bus encryption.
thedanshires
Re: ASUS BC-12D2HT
Hi Mike
I have this drive too, just wondered if there's any kind of timeline when unrestricted read speed will be implemented please? Or is it just a case of it'll be done when it done?
Thanks for this amazing programme.
Re: ASUS BC-12D2HT
Hello guys,
just fyi, I have the BC-12D2HT and I'm perfectly able to use MakeMKV in combination with this drive to save my UHD Blu Ray disk to my NAS.
So, I'm kinda curious why everyone says that the drive isn't able to - in fact it was even before I flashed that LibreDrive firmware onto it.
Or am I missing something?
Re: ASUS BC-12D2HT
I believe there are two versions of this drive? Mine is a 2016 model and it reads UHD discs as the factory firmware is friendly, I keep this one in reserve in case my daily driver Asus ever gives up. but think there is an older version with no UHD capability?
Re: ASUS BC-12D2HT
Forum search function works:Rayxcer wrote: ↑Thu Jun 13, 2019 1:30 pmHello guys,
https://www.makemkv.com/forum/viewtopic ... 2HT#p74990
https://www.makemkv.com/forum/search.ph ... =BC-12D2HT
Discussed multiple times already.
Re: ASUS BC-12D2HT
can anyone dump the firmware for the old "not patchable yet" version of ASUS BC-12D2HT?
That is, the drive Tntdruid listed the MakeMKV output from:
Product: BC-12D2HT
I was stupid and did not read all forum threads about BC-12D2HT and upgraded it to 3.01,
and now it just opens and closes fine, but will not read anything.
OS device name: E:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.01
Serial number: SIK9OXXXXXXX
Firmware date: 2117-11-15 19:26
Firmware version: 3.01
If someone can dump the original 1.00 fw for it, I will try to downgrade.
Product: BC-12D2HT
OS device name: E:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.01
Re: ASUS BC-12D2HT
is it possible to crossflash this drive for using with opti drive control to scan for error?
Re: ASUS BC-12D2HT
Try BH16NS58 with qpxtools. Optidrive is buggy anyway.
Re: ASUS BC-12D2HT
so this drive with BH16NS58 FW can scan discs? (qpxtools, opti drive..)
good for its price. thanks Coopervid
