he says me after i open an iso file that i use anydvd, i should deactive it and restart makemkv.. i have no anydvd on my computer i have no other software as makemkv on my computer... i can countinue but he says it can make some errors. whats wrong?
First Try - open Iso file with MakeMKV
Re: First Try - open Iso file with MakeMKV
If the ISO was created by AnyDVD, whether or not AnyDVD is running is irrelevant. The ISO may have defects from its creation.
For the most part, AnyDVD has fixed the problems they used to have with corrupting the data. But the warning is in place because the possibility still exists. If the file isn't corrupted, continuing is not an issue.
