Unable to copy Avatar DVD
spilote
Post by spilote » Thu Aug 19, 2010 6:36 pm
I read few thread on Avatar BD but I can't find any help for DVD.
I'm trying to copy Avatar DVD and getting the following error.
Any help !?
MakeMKV v1.5.8 win(x86-release) started
Drive BD-ROM ATAPI iHOS104 WL0B has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Title #0 has length of 9692 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
Title #3 has length of 7 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
Title #5 has length of 7 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
Title #6 has length of 34 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
Title #8 has length of 43 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
Title #10 has length of 11 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
Title #11 has length of 5 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
Title #15/1 has length of 5 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
Title #15/2 has length of 6 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
Title #17 has length of 10 seconds which is less than minimum title length of 18540 seconds and was therefore skipped
setarip_old
Re: Unable to copy Avatar DVD
Post by setarip_old » Fri Aug 20, 2010 11:58 pm
I don't know where that number came from, but it's absurd! - Greater than 5 hours!.
Try changing minimum title length to the original default of 120 seconds(2 minutes) or less (I have mine set at 2 seconds).
What version number of MakeMKV are you using?
Where did you obtain it?
