Bum drive, or Bum discs? ASUS BW-16D1HT 3.00d
thirdgen89gta
#1 Post by thirdgen89gta » Mon Mar 11, 2019 12:09 am
Having an issue with some 4K UHD discs. About halfway through they'll crash out with some kind of Medium or Posix error. I've had it happen on a few discs. Notably Oblivion was the first disc to fail, but recently in the logs below its Infinity War.
These discs are CLEAN. I've washed them with a microfiber towel even though there was not even a smudge.
So my question is, is it the disc, or the drive thats having issues? If its the drive I'll buy another drive and relegate this one to non-4K discs. The drive is about 1 year old.
Drive is a ASUS BW-16D1HT, Firmware 3.00d in an NexStar USB3 enclosure on my Mac, however I have also directly attached it to a windows PC as an internal drive. The two logs are of the same disk. First log is when its directly attached as an internal drive on my Gaming PC.
I'm not sure if doing a firmware upgrade is going to fix it, and when it comes to drive firmware I usually won't touch it ever unless a problem crops up, so I am looking at the firmware threads on these forums now. Just not sure if that's going to fix my issues.
The 2nd log is attached via USB3 on my MacMini.
Log is from drive when direction attached via SATA cable internally.
MakeMKV v1.14.2 win(x64-release) started
Downloading latest SDF to C:\Users\third/.MakeMKV ...
Using LibreDrive mode (v04 id=F0ED16432FAA)
Downloading latest HK to C:\Users\third/.MakeMKV ...
Title #00101.mpls has length of 10 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00900.mpls has length of 20 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00106.mpls has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
File 00020.mpls was added as title #0
Title #00002.mpls has length of 3 seconds which is less than minimum title length of 45 seconds and was therefore skipped
File 00004.mpls was added as title #1
File 00800.mpls was added as title #2
Title #00902.mpls has length of 30 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00300.mpls has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00103.mpls has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00304.mpls has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00303.mpls has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00302.mpls has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00016.mpls has length of 3 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00042.mpls has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00015.mpls has length of 3 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00105.mpls has length of 21 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00301.mpls has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00041.mpls has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00040.mpls has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00102.mpls has length of 10 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00307.mpls has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00901.mpls has length of 20 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00306.mpls has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00305.mpls has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00052.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00060.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00010.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00019.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00050.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00051.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00043.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00035.m2ts has length of 41 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00030.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00063.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00006.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00039.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00047.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00046.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00045.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00044.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00061.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00018.m2ts has length of 30 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00059.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00064.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00062.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00150.m2ts has length of 1 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00011.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00038.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00037.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00036.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00033.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00009.m2ts has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00151.m2ts has length of 2 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00015.m2ts has length of 0 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
Title 00004.mpls is equal to title 00800.mpls and was skipped
Saving 1 titles into directory C:/Users/third/Videos/Avengers - Infinity War (2018)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '31778598912'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31778598912'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '31801933824'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31801933824'
Failed to save title 1 to file C:/Users/third/Videos/Avengers - Infinity War (2018)/MARVEL'S AVENGERS- INFINITY WAR_t01.mkv
Encountered 23 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
And the log from the same drive, now in the NexStar USB3 enclosure attempting to rip the exact same disc.
MakeMKV v1.14.2 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/william/MakeMKV_log.txt
Optical drive "BD-RE ASUS BW-16D1HT 3.00d" opened in OS access mode.
Saving 1 titles into directory /Users/Shared/Media/Masters/MARVEL'S AVENGERS- INFINITY WAR
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '31826509824'
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk2' at offset '31826509824'
DEBUG: Code 1073741830 at oR=Y1>iTZ?NprdY6aW:29395080
DEBUG: Code 2281701379 at oR=Y1>iTZ?NprdY6aW:29395080
DEBUG: Code 0 at )o^[7#n9G2L$z#ybU`mC:29395011
DEBUG: Code 0 at QXq-~p=E9 #}S?W)9NI|:29394068
DEBUG: Code 0 at )o^[7#n9G2L$z#ybU`mC:29394459
DEBUG: Code 15540288 at )o^[7#n9G2L$z#ybU`mC:29393286
DEBUG: Code 0 at "O@}W`.ZWi2muU=C9/=\I:213136608
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 1 to file /Users/Shared/Media/Masters/MARVEL'S AVENGERS- INFINITY WAR/MARVEL'S AVENGERS- INFINITY WAR_t01.mkv
Encountered 11 errors of type 'OS X IPC Error' - see http://www.makemkv.com/errors/ipc/
Re: Bum drive, or Bum discs? ASUS BW-16D1HT 3.00d
#2 Post by Woodstock » Mon Mar 11, 2019 12:22 am
The drive is finding unreadable spots near each other in both situations, which usually points to a dirty disk. The fact that they aren't in the EXACT same spot usually means that you will be OK after cleaning the disk. Exact same spots often mean scratches or other flaws that cleaning won't fix.
thirdgen89gta
#3 Post by thirdgen89gta » Mon Mar 11, 2019 1:33 am
Disc has already been cleaned and looks flawless. So its either a poorly mastered disc, or a bad drive. The question is which.
#4 Post by Woodstock » Mon Mar 11, 2019 3:24 am
Without a different drive to test on, it is very hard to eliminate the drive. The 'OS error - STATUS_DEVICE_DATA_ERROR' and 'OS error - (ipc/send) invalid destination port' usually occur when the drive is trying "too hard" to read the disk, and stops listening to the operating system for a while.
