Heads up - Support for LG UHD drives
Dave77
Re: Heads up - Support for LG UHD drives
#181 Post by Dave77 » Fri Mar 08, 2019 1:47 pm
spl147 wrote: Fri Mar 08, 2019 12:53 pm Use the LG patched flasher and the 1.0 DE enabled firmware and you can use it now
Thanks. Do you have a link to instructions, I can find lots on the Asus but not the LG
#182 Post by d00zah » Fri Mar 08, 2019 1:55 pm
Dave77 wrote: Fri Mar 08, 2019 1:47 pm Thanks. Do you have a link to instructions, I can find lots on the Asus but not the LG
1st link in this thread:
viewtopic.php?f=16&t=18933#p70766
is to an archive containing both the tool & the prepared firmware images.
#183 Post by Coopervid » Fri Mar 08, 2019 10:10 pm
xxcalibur
#184 Post by xxcalibur » Sat Mar 09, 2019 1:41 pm
hey fellas. i just purchased the same LG drive as Dave77. i'd like to start using my drive to backup my 4k collection and after reading this thread i just wanted to get confirmation that im using the right tool and firmware. i've grabbed the zip file containing the asus tool and firmware. so if i use the asus tool and this firmware:
"DE_LG WH16NS60_1.00.bin" i'll get good to go?
spl147 said to use the "Use the LG patched flasher" but i only see the asus one in the zip file..is that considered the same?
thanks guys, i appreciate everything you all do for this group
xxcalibur
Dave77
#185 Post by Dave77 » Sat Mar 09, 2019 6:24 pm
xxcalibur wrote: Sat Mar 09, 2019 1:41 pm hey fellas. i just purchased the same LG drive as Dave77.
V1.01 is going to be supported soon apparently, might be worth waiting a bit.
xxcalibur
#186 Post by xxcalibur » Sat Mar 09, 2019 7:24 pm
Cool. Thanks Dave. I'd rather not flash and run the risk of screwing up the drive.
Thanks again.
Xxcalibur
#187 Post by MartyMcNuts » Sat Mar 09, 2019 10:27 pm
xxcalibur wrote: Sat Mar 09, 2019 1:41 pm hey fellas. i just purchased the same LG drive as Dave77. i'd like to start using my drive to backup my 4k collection and after reading this thread i just wanted to get confirmation that im using the right tool and firmware. i've grabbed the zip file containing the asus tool and firmware. so if i use the asus tool and this firmware:
xxcalibur
Correct. FYI, Both the modified ASUS tool and the LG tool do the same thing.
xxcalibur
#188 Post by xxcalibur » Sat Mar 09, 2019 10:47 pm
thanks for clarification MartyMcNuts :D
plittlefield
#189 Post by plittlefield » Sun Mar 10, 2019 9:34 pm
Hi Folks,
I have just bought a WH14NS40 with SVC: NS50 and firmware 1.03 manufactured in November 2018.
Is this the correct forum thread or should I buy the WH16NS60 instead?
Thanks,
Paully
#190 Post by Billycar11 » Mon Mar 11, 2019 12:37 am
plittlefield wrote: Sun Mar 10, 2019 9:34 pm Hi Folks,
Thanks,
Paully
that will work follow my how to video here: https://www.youtube.com/watch?v=Yfpf6HoMMis
xxcalibur
#191 Post by xxcalibur » Mon Mar 11, 2019 9:02 pm
hey mate..will your quide work with this model? WH14NS40 with SVC: NS40?
i have an old NS40 but i see where the original post called out the same drive but an SVC of NS50...just curious if it will work.
thanks
xxcalibur
#192 Post by d00zah » Mon Mar 11, 2019 9:21 pm
xxcalibur wrote: Mon Mar 11, 2019 9:02 pm hey mate..will your quide work with this model? WH14NS40 with SVC: NS40?
thanks
xxcalibur
No. If you try, bad things happen. See:
viewtopic.php?f=16&t=19071
viewtopic.php?f=16&t=18873&start=75#p71423
xxcalibur
#193 Post by xxcalibur » Mon Mar 11, 2019 10:55 pm
yeah i figured it wouldn't work but it doesn't hurt to ask LOL. i did just buy and install a new LG WH16NS60. just waiting for the program to accept it so i can start backing up my 4k collection.
thanks d00zah
#194 Post by d00zah » Mon Mar 11, 2019 11:09 pm
xxcalibur wrote: Mon Mar 11, 2019 10:55 pm yeah i figured it wouldn't work but it doesn't hurt to ask LOL. i did just buy and install a new LG WH16NS60. just waiting for the program to accept it so i can start backing up my 4k collection.
thanks d00zah
Now THAT one's possible... fairly straight forward.
BermudaLamb
#195 Post by BermudaLamb » Thu Mar 21, 2019 1:50 pm
I'm running a pc on Windows 10.
I have a brand new LG WH16NS60 v1.01 installed in a USB3.0 drive case. This was purchased because it was indicated on the forum that this is one of the "official" supported UHD drives.
I've tried to use the latest version of MakeMKV to read many of my 4kUHD movie discs. All have failed with a SCSI read error.
Step-by-step, what exactly do I need to do in order to get this "official" drive to work with MakeMKV and my library of 4kUHD discs.
Do I need to mount it internally?
Do I need to change the firmware?
Do I need to install LibreDrive?
Please ... provide guidance and instructions, along with any appropriate links.
