Juliet, Naked Redbox correct DVD playlist
Hi all,
Unfortunately, this film has playlist obfustication. Just wondering if someone could provide me with the correct playlist for the Redbox version.
Re: Juliet, Naked Redbox correct DVD playlist
MakeMKV did not recommend a playlist.
I thought it was one of those discs that has 7 playlists but only one ended up copying. Instead 4 copied and 2 failed. 3 of the four are similar in segment map. One segment map is different and time is different. There is t07 at 1:37:21 / 2-18 might be it instead of the four that are about 1:35:00 / 6-23 / t08, t09 or t10.
One playlist DID NOT bubble up to the top and say MAIN FEATURE (I can't remember what it actually usually says.
vlc reports the correct title as "70".
MakeMKV says:
And this closely matches:
My other backup utilities were not able to copy this disc.
MakeMKV says:
Title #70 was added (17 cell(s), 1:37:21)
Source title ID: 59
Duration: 1:37:21
Chapters count: 17
Segment count: 1
Segment map: 2-18
File name: title_t03.mkv
That only works with Blu-Ray’s.RickInHouston wrote: ↑Tue Nov 13, 2018 4:54 pmMakeMKV did not recommend a playlist.
You would use the same process here that you and I discussed in the Chappaquiddick thread.
Registered User
Buy MakeMKV
Buy MakeMKV
Anyone know the rental version title number? I don't have a 70 on my blu ray.
Netflix reports:
Name: Juliet, Naked (English)
Comment: FPL_MainFeature
Source file name: 00753.mpls
Duration: 1:37:34
Chapters count: 16
Segment count: 20
Segment map: 519,505,506,513,518,512,517,520,511,504,510,501,516,503,509,502,514,515,507,508
Duration: 1:37:34
Chapters count: 16
Segment count: 20
This is the DVD forum. You need to post the Blu-ray results here: viewtopic.php?f=8&t=18351
Read this thread and you'll be able to figure out the correct title to rip on the DVD, and then you can post the correct one back to this thread.
viewtopic.php?f=7&t=17806
my dvd drive read it fine I just had to use another program i imagine my problem was that either the disc was dirty or i had not set up make mkv right and i had to abort midway through opening the disc .I think normally make mkv gives me the correct choice on this occasion it did not but im still happy with the program .keep owking your magic mike
I just ripped this on Handbrake using title 58 successfully. I know others that contributed to this tread probably figured it out, but it sucks that no one ever takes the time to share their success.
This will always be difficult for Lionsgate DVD's due to their spoofing technology that is designed to fool rip engines. The only way I ever figure it out is to try each title until one works. I have the most success using Handbrake vs. MakeMKV for this.
So....for those that figure out the correct titles for these hard to rip titles, PLEASE post your success...with the proper rip title. Thanks!
for me the correct blu-ray list was:
Title information
Source file name: 00647.mpls
Duration: 1:37:34
Chapters count: 16
Segment count: 20
Segment map: 519,512,505,517,506,513,518,520,511,504,510,501,503,516,509,502,507,515,514,508
File name: Juliet, Naked_t275.mkv
Title information
Duration: 1:37:34
Chapters count: 16
Segment count: 20
