The Matrix UHD
Mitalis
The Matrix UHD
Post by Mitalis »
Trying to rip the Matrix UHD, and at some point while ripping the disk, I'm getting a hash check error. Below are my device specs. A log of the errors is attached. Any assistance would be appreciated as to getting around this. Thanks.
Product: BD-RE WH14NS40
Revision: 1.02
Serial number: <redacted>
Firmware date: 2115-12-11 15:03
Highest AACS version: 61
Firmware version: 1.02
Disc Information
Label: THE_MATRIX
Timestamp: 2018-03-30 16:29:39
Data capacity: 58.57 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Matrix UHD makeMKV log.txt
(80.82 KiB) Downloaded 621 times
Re: The Matrix UHD
DEBUG: Code 502 at XRO[?3BP.>,Vp$f$!t'x:213131318
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 25181140992, attempting to work around
DEBUG: Code 503 at XRO[?3BP.>,Vp$f$!t'x:213131318
DEBUG: Code 504 at XRO[?3BP.>,Vp$f$!t'x:213131318
These are usually signs of a dirty disk. Have you tried cleaning it?
Although, you might be experiencing this: viewtopic.php?f=8&t=18833
