Got it on ebay, works like a champ!
Heads up - Support for LG UHD drives
Re: Heads up - Support for LG UHD drives
If you're going to buy a drive, buy it here, don't support those guys on eBay.
nicksilverstein
Do you still have the BU40N 1.00 firmware? Can you please send it to me?jonghotti wrote: Fri Feb 08, 2019 11:45 pm Yes it needs to be flashed with BU40N 1.00 which I am happy to send you. Alternatively I'll swap you a BU50N with supported firmware for yours.
Hi, mine reads the following, will it be supported in the future?
Product: BD-RE WH16NS60
Revision: 1.01
Harware support: Yes
Firmware support: No
Firmware version: 1.01
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
Revision: 1.01
Use the LG patched flasher and the 1.0 DE enabled firmware and you can use it nowDave77 wrote:Hi, mine reads the following, will it be supported in the future?
Revision: 1.01
Sent from my iPhone Xs Max using Tapatalk Pro
Thanks. Do you have a link to instructions, I can find lots on the Asus but not the LGspl147 wrote: Fri Mar 08, 2019 12:53 pm Use the LG patched flasher and the 1.0 DE enabled firmware and you can use it now
1st link in this thread:Dave77 wrote: Fri Mar 08, 2019 1:47 pm Thanks. Do you have a link to instructions, I can find lots on the Asus but not the LG
viewtopic.php?f=16&t=18933#p70766
is to an archive containing both the tool & the prepared firmware images.
hey fellas. i just purchased the same LG drive as Dave77. i'd like to start using my drive to backup my 4k collection and after reading this thread i just wanted to get confirmation that im using the right tool and firmware. i've grabbed the zip file containing the asus tool and firmware. so if i use the asus tool and this firmware:
"DE_LG WH16NS60_1.00.bin" i'll get good to go?
spl147 said to use the "Use the LG patched flasher" but i only see the asus one in the zip file..is that considered the same?
thanks guys, i appreciate everything you all do for this group
xxcalibur
xxcalibur
V1.01 is going to be supported soon apparently, might be worth waiting a bit.
Cool. Thanks Dave. I'd rather not flash and run the risk of screwing up the drive.
Thanks again.
Xxcalibur
Thanks again.
Xxcalibur
Correct. FYI, Both the modified ASUS tool and the LG tool do the same thing.xxcalibur wrote: Sat Mar 09, 2019 1:41 pm hey fellas. i just purchased the same LG drive as Dave77. i'd like to start using my drive to backup my 4k collection and after reading this thread i just wanted to get confirmation that im using the right tool and firmware. i've grabbed the zip file containing the asus tool and firmware. so if i use the asus tool and this firmware:
xxcalibur
thanks for clarification MartyMcNuts
plittlefield
Hi Folks,
I have just bought a WH14NS40 with SVC: NS50 and firmware 1.03 manufactured in November 2018.
Is this the correct forum thread or should I buy the WH16NS60 instead?
Thanks,
Paully
Thanks,
Paully
that will work follow my how to video here: https://www.youtube.com/watch?v=Yfpf6HoMMisplittlefield wrote: Sun Mar 10, 2019 9:34 pm Hi Folks,
Thanks,
Paully
