The Last Song (2010)
MakeMKV is crashing after reading this disc, just released today.
Debug log started at Tue Aug 17 23:57:20 2010 , written by MakeMKV v1.5.8 win(x64-release)
001005:0000 MakeMKV v1.5.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\syntax/MakeMKV_log.txt
DISCID=A08F6C3372F31FA32E20FF1347FEB485B78332B9
001003:0020 DEBUG: Code 47 at dnHF)'g8xX"dX2{dZF&:213130858
003307:0000 File 00064.mpls was added as title #0
003307:0000 File 00042.mpls was added as title #1
003025:0000 Title #00012.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00042.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00043.m2ts was added as title #2
003025:0000 Title #00044.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00045.m2ts was added as title #3
003025:0000 Title #00046.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00047.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00048.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00049.m2ts was added as title #4
003307:0000 File 00050.m2ts was added as title #5
003307:0000 File 00051.m2ts was added as title #6
003025:0000 Title #00055.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00062.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00063.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00064.m2ts was added as title #7
003025:0000 Title #00065.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00066.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00067.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00068.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00069.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00070.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00071.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00072.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00076.m2ts was added as title #8
005011:0000 Operation sucessfully completed
csf6
Application exited at Tue Aug 17 23:58:01 2010
csf6
setarip_old
Re: The Last Song (2010)
Hi!
Were the 8 titles saved to your hard drive?
No, it crashes as soon as it's done scanning the disc.
setarip_old
Try doing a full disc backup (checkmark "DECRYPTED"). If successful, use this full disc backup as the source for your attempt to create .MKV(s)...
Disc backs up fine. However, when I try to open the disc from the backup it crashes at the same spot (right after scanning the structure).
comporder1
syntax53,
Did you ever figure this one out? I am having the same issue.
Nope, still waiting for a response from the DEVs
comporder1
There may be a better way than this....... I used AnyDVD to "rip video DVD to harddisk". Then used TSmuxer to setup the main movie file for MakeMKV (output to "blu-ray disk"). Worked fine for me, but took a while.
Same issue here. Won't even open the disc. Crashes. Unfortunate this happens on such a lame chick flick, but my wife is relentless:
Process: makemkv [8367]
Path: /Applications/Rock Star Blu-Unity Encoder.app/Contents/MacOS/makemkv
Identifier: com.makemkv.MakeMKV
Version: v1.5.8 (0)
Code Type: X86 (Native)
Parent Process: launchd [326]
Date/Time: 2010-08-20 13:44:50.184 -0700
OS Version: Mac OS X 10.6.4 (10F569)
Report Version: 6
Interval Since Last Report: 507864 sec
Crashes Since Last Report: 20
Per-App Interval Since Last Report: 389472 sec
Per-App Crashes Since Last Report: 6
Anonymous UUID: FF269FC0-0259-4D4D-A983-BB5617AB6F5B
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000025
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.makemkv.MakeMKV 0x0000d88d 0x1000 + 51341
1 com.makemkv.MakeMKV 0x000058ac 0x1000 + 18604
2 com.makemkv.MakeMKV 0x0001b188 0x1000 + 106888
3 com.makemkv.MakeMKV 0x000575d7 0x1000 + 353751
4 com.makemkv.MakeMKV 0x00068469 0x1000 + 423017
5 com.makemkv.MakeMKV 0x00058615 0x1000 + 357909
6 com.makemkv.MakeMKV 0x0006bc46 0x1000 + 437318
7 com.makemkv.MakeMKV 0x00070676 0x1000 + 456310
8 com.makemkv.MakeMKV 0x0004f7c3 0x1000 + 321475
9 com.makemkv.MakeMKV 0x002464d5 0x1000 + 2381013
10 com.apple.HIToolbox 0x9016bf2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
11 com.apple.HIToolbox 0x9016b1f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
12 com.apple.HIToolbox 0x9016b055 SendEventToEventTargetWithOptions + 58
13 com.apple.HIToolbox 0x9019fbb0 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3006
14 com.apple.HIToolbox 0x9016c380 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
15 com.apple.HIToolbox 0x9016b1f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
16 com.apple.HIToolbox 0x9018d9bb SendEventToEventTarget + 52
17 com.makemkv.MakeMKV 0x00241901 0x1000 + 2361601
18 com.makemkv.MakeMKV 0x0024b1f2 0x1000 + 2400754
19 com.makemkv.MakeMKV 0x0004f148 0x1000 + 319816
20 com.makemkv.MakeMKV 0x0004f377 0x1000 + 320375
21 com.makemkv.MakeMKV 0x00050a98 0x1000 + 326296
22 com.makemkv.MakeMKV 0x00002f7f 0x1000 + 8063
23 com.makemkv.MakeMKV 0x00002d02 0x1000 + 7426
24 com.makemkv.MakeMKV 0x00002c29 0x1000 + 7209
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x948bb942 kevent + 10
1 libSystem.B.dylib 0x948bc05c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x948bb519 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x948bb2be _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x948bad41 _pthread_wqthread + 390
5 libSystem.B.dylib 0x948bab86 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x948950fa mach_msg_trap + 10
1 libSystem.B.dylib 0x94895867 mach_msg + 68
2 com.unsanity.ape 0x00492f02 __ape_agent + 255
3 libSystem.B.dylib 0x948c281d _pthread_start + 345
4 libSystem.B.dylib 0x948c26a2 thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x9489515a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x948c2ca5 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x9490b410 pthread_cond_timedwait + 47
3 com.makemkv.MakeMKV 0x0006158f 0x1000 + 394639
4 com.makemkv.MakeMKV 0x0006162f 0x1000 + 394799
5 com.makemkv.MakeMKV 0x00003194 0x1000 + 8596
6 com.makemkv.MakeMKV 0x00061799 0x1000 + 395161
7 libSystem.B.dylib 0x948c281d _pthread_start + 345
8 libSystem.B.dylib 0x948c26a2 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x0000b430 ecx: 0xbfffe25c edx: 0x00415001
edi: 0x0104faa4 esi: 0x00000800 ebp: 0xbfffe2f8 esp: 0xbfffe160
ss: 0x0000001f efl: 0x00010206 eip: 0x0000d88d cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000025
Binary Images:
0x1000 - 0x414fef +com.makemkv.MakeMKV v1.5.8 (0) <899B9514-2511-4F0D-959A-E6937499338E> /Applications/Rock Star Blu-Unity Encoder.app/Contents/MacOS/makemkv
0x491000 - 0x4a5ff7 +com.unsanity.ape 2.6 (2.6) <ABDF4582-9335-06F9-D311-9E9555588079> /Library/Frameworks/ApplicationEnhancer.framework/Versions/A/ApplicationEnhancer
0x708000 - 0x723ff3 +com.unsanity.windowshadex 5.0.4 (30000369) <3E0AB10E-477C-1D69-1252-5272A870749E> /Users/Josh/Library/Application Enhancers/WindowShade X.ape/Contents/MacOS/WindowShade X
0x795000 - 0x7a3fe7 libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8F5FA7F7-840D-C5EF-C6E6-E2AF7CE43CD2> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x7c5000 - 0x7d7ff7 libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <026B8702-B0A6-1D90-BBD6-AAAD2E14810D> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
0x90164000 - 0x90488fef com.apple.HIToolbox 1.6.3 (???) <0A5F56E2-9AF3-728D-70AE-429522AEAD8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x90783000 - 0x907c5ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x907c6000 - 0x9086fff7 com.apple.CFNetwork 454.9.7 (454.9.7) <B740E1BD-01B7-34C2-2A9A-6DBC68B1EA5B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90870000 - 0x908b4ff3 com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x908b5000 - 0x908b5ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x90915000 - 0x909c3ff3 com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x909fe000 - 0x90d66ff7 com.apple.QuartzCore 1.6.2 (227.22) <4288F0D2-0C87-F054-C372-8764B44DE024> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90d67000 - 0x90de7feb com.apple.SearchKit 1.3.0 (1.3.0) <2F5DE102-A203-7905-7D12-FCBCF17BAEF8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x90de8000 - 0x90de8ff7 com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x90ebe000 - 0x90f0eff7 com.apple.framework.familycontrols 2.0.1 (2010) <B9762E20-543D-13B9-F6BF-E8585F04CA01> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x90f29000 - 0x910abfe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <2314BD12-0821-75BB-F3BC-98D324CFD30A> /usr/lib/libicucore.A.dylib
0x911b5000 - 0x91a95ff7 com.apple.AppKit 6.6.6 (1038.29) <6F28C335-6DC2-AE0E-B79A-F256DBD0BB45> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x91b05000 - 0x91b2dff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x91b2e000 - 0x91b31ff7 libCoreVMClient.dylib ??? (???) <CA0BA8DC-0159-A808-A300-750358A6970C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x91b4b000 - 0x91b55fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x91b56000 - 0x91b89ff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91b9a000 - 0x91ba8fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
0x91be2000 - 0x91c2bfe7 libTIFF.dylib ??? (???) <9CFF48CC-4852-4D06-17AC-3C947C824159> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91cac000 - 0x91cb6ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <45083DBA-5EA4-9B90-8BEB-A089E515180F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x91cb7000 - 0x91cf4ff7 com.apple.SystemConfiguration 1.10.2 (1.10.2) <398BB007-41FD-1A30-26D8-CB86ED5E467E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91cf5000 - 0x91d05ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x91ee9000 - 0x91f07ff7 com.apple.CoreVideo 1.6.1 (45.4) <E0DF044D-BF31-42CE-B690-FD1FCE07E64A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x91f08000 - 0x91f2afef com.apple.DirectoryService.Framework 3.6 (621.3) <05FFDBDB-F16B-8AC0-DB42-986965FCBD95> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x91f9a000 - 0x91f9aff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91ff2000 - 0x9204dff7 com.apple.framework.IOKit 2.0 (???) <A013B850-6ECB-594A-CBD6-DB156B11871B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x9204e000 - 0x9214ffe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <89E648DC-E865-0AF4-5D4D-9562458FE939> /usr/lib/libxml2.2.dylib
0x92164000 - 0x921a7ff7 libGLU.dylib ??? (???) <2093A1FB-67BD-39E0-CDE5-A97A77BDDBCE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92227000 - 0x92235ff7 com.apple.opengl 1.6.9 (1.6.9) <4F06C166-00CF-5ACF-77E3-5A960A5E8AD3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x92236000 - 0x92238ff7 libRadiance.dylib ??? (???) <AB06F616-E3EA-5966-029A-8AA44BBE5B28> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x92239000 - 0x9223ffff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x923bb000 - 0x923bfff7 libGFXShared.dylib ??? (???) <2D32BDBF-C941-93FD-E233-F03D28DB9E94> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x923c0000 - 0x923c3ff7 libCGXType.A.dylib 543.50.0 (compatibility 64.0.0) <3B49AED9-0DBA-9D21-F9AC-8784363AD762> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x923c4000 - 0x92bb3557 com.apple.CoreGraphics 1.543.50 (???) <74533178-5C90-0F54-1B06-2E1C5251ED5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x92bb4000 - 0x92bbfff7 libGL.dylib ??? (???) <B87E0676-F5EF-8DA3-6DEE-13C43B3832A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92bc0000 - 0x92bf1ff3 libTrueTypeScaler.dylib ??? (???) <7601D717-236D-8F4E-91F5-E69BB2920478> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x92f72000 - 0x93292feb com.apple.CoreServices.CarbonCore 861.13 (861.13) <52803668-3669-36BD-57DD-078FBA835081> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x93293000 - 0x9344dfe3 com.apple.ImageIO.framework 3.0.3 (3.0.3) <A93A514B-C1BF-21D0-FB03-CB775DE4FFAA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9344e000 - 0x9347fff7 libGLImage.dylib ??? (???) <9340012D-595A-6243-9C97-7D30D76D9D9E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x93480000 - 0x936f0ffb com.apple.Foundation 6.6.3 (751.29) <E77D3906-99F4-FEF4-FBB0-86FB3C94073E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9374a000 - 0x93755ff7 libCSync.A.dylib 543.50.0 (compatibility 64.0.0) <4FA0CE4A-BDE5-0E3D-37F0-03B41F0C2637> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x93830000 - 0x93832ff7 com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x938e6000 - 0x93968ffb SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x93969000 - 0x93bccfef com.apple.security 6.1.1 (37594) <8AE73F5F-936C-80F6-B05B-A50C3082569C> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x93bcd000 - 0x93bcdff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93bff000 - 0x93c14fff com.apple.ImageCapture 6.0 (6.0) <0E86F45E-E656-9015-7AD4-A2C5F8D8A2FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x93e43000 - 0x93e67ff7 libJPEG.dylib ??? (???) <5CE96981-6B2A-D15B-4A17-E7BD329095B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x93e68000 - 0x93f18ff3 com.apple.ColorSync 4.6.3 (4.6.3) <AA1076EA-7665-3005-A837-B661260DBE54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x93f55000 - 0x9400efe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x9400f000 - 0x941eaff3 libType1Scaler.dylib ??? (???) <3CCADAB2-FBBF-15C9-C70C-4D26746B309E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x941eb000 - 0x9422ffe7 com.apple.Metadata 10.6.3 (507.10) <630494FA-3BB3-EDD3-E10B-8DAAF4831E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x942df000 - 0x94377fe7 edu.mit.Kerberos 6.5.10 (6.5.10) <8B83AFF3-C074-E47C-4BD0-4546EED0D1BC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x94378000 - 0x94398fe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
0x94399000 - 0x94463fef com.apple.CoreServices.OSServices 357 (357) <CF9530AD-F581-B831-09B6-16D9F9283BFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9459c000 - 0x9459dff7 com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9459e000 - 0x946aaff7 libGLProgrammability.dylib ??? (???) <1B315838-F477-5416-7504-67EC3433AD4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x94725000 - 0x947b7fe3 com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x947b8000 - 0x94893fe7 com.apple.DesktopServices 1.5.7 (1.5.7) <A69072AD-C47E-A00D-4A69-6E46A7FB2119> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x94894000 - 0x94a3afeb libSystem.B.dylib 125.2.0 (compatibility 1.0.0) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
0x94a50000 - 0x94a91ff7 libRIP.A.dylib 543.50.0 (compatibility 64.0.0) <8BAE1FC1-A478-F151-17C7-2D5DE470AC4F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94a92000 - 0x94aa3ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x94aa7000 - 0x94ab9ff7 com.apple.MultitouchSupport.framework 205.34 (205.34) <813475E3-B323-9405-F758-DDA1F5D63B20> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x94fde000 - 0x95004fff com.apple.DictionaryServices 1.1.1 (1.1.1) <B4344524-2EC0-D4C7-85B6-8A8CC6A5DCEA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9537c000 - 0x954f6fe3 com.apple.CoreFoundation 6.6.3 (550.29) <00373783-3744-F47D-2191-BEEA658F0C3D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x954f7000 - 0x954f7ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x95798000 - 0x957a5ff7 com.apple.NetFS 3.2.1 (3.2.1) <1F28472D-9913-B8CE-B025-BBA52372F568> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x957d0000 - 0x95886ffb libFontParser.dylib ??? (???) <067DC1A2-764B-41EA-B07E-4205472749B7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x958c0000 - 0x958c0ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x958cf000 - 0x958d3ff7 libGIF.dylib ??? (???) <3ECD4D2C-40FE-E9A0-A2D2-E36D1C00D3A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x958d4000 - 0x958f0fe3 com.apple.openscripting 1.3.1 (???) <DE20A1B9-F9B6-697C-B533-F5869BA43077> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9597a000 - 0x95d90ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x95d91000 - 0x95de2ff7 com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x95de3000 - 0x95e1efeb libFontRegistry.dylib ??? (???) <A102F61F-25D5-001A-20C3-56304C585072> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x95e1f000 - 0x95e33ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <0DBE17D5-17A2-8A0E-8572-5A78408B41C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x95e34000 - 0x95e3dff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x95f82000 - 0x95f9aff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x96eec000 - 0x96f67fe7 com.apple.audio.CoreAudio 3.2.2 (3.2.2) <51D0E2DC-B15F-AF6C-70D8-026DDAD4E2A5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x96f68000 - 0x97015fe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <3308DD74-5D03-6189-2AFD-63BF06848E91> /usr/lib/libobjc.A.dylib
0x97016000 - 0x97059ff7 com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x97171000 - 0x97172ff7 com.apple.TrustEvaluationAgent 1.1 (1) <8C570606-D77C-738E-7148-6B28846F0B3C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9717a000 - 0x9717eff7 IOSurface ??? (???) <66E11D8E-CF4B-EFD0-37F9-20177C647021> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x97bd2000 - 0x97bedff7 libPng.dylib ??? (???) <36A3D75E-5178-4358-7F02-444E276D61AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x97bee000 - 0x97ce0ff7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.
<D2C86308-F998-C83D-F49B-CD484D4EFE6A> /usr/lib/libcrypto.0.9.8.dylib
0x97cf0000 - 0x97d51fe7 com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x97d71000 - 0x97d7dff7 libkxld.dylib ??? (???) <322A4B52-8305-3081-6B74-813C3A87A56D> /usr/lib/system/libkxld.dylib
0x97d9e000 - 0x97de4ff7 libauto.dylib ??? (???) <9A2E444C-89BD-2902-C1E6-EC3E92544A25> /usr/lib/libauto.dylib
0x97e6a000 - 0x97f05ff7 com.apple.ApplicationServices.ATS 4.3 (???) <7ECA252B-5F67-2816-A4F0-73E1DC833728> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x98077000 - 0x9811fffb com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x98120000 - 0x981bdfe3 com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x981be000 - 0x981d2fe7 libbsm.0.dylib ??? (???) <821E415B-6C42-D359-78FF-E892792F8C52> /usr/lib/libbsm.0.dylib
0x981f1000 - 0x98229ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <76C02F5C-98FD-BD64-B5FB-C698FB76EA25> /usr/lib/libcups.2.dylib
0x9822a000 - 0x9822aff7 com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x98a25000 - 0x98a2aff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x98a33000 - 0x98a36ffb com.apple.help 1.3.1 (41) <EF92C648-2085-C085-8EA7-A1AF37AE94F4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x98a37000 - 0x98a3afe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x98a3d000 - 0x98aa1ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x98acd000 - 0x98b1afeb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <52906E26-3D22-6F37-8C90-E50BBCDEA5D0> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x98b1b000 - 0x98b22ff3 com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x98b5c000 - 0x98b7dfe7 com.apple.opencl 12.1 (12.1) <DA2AC3FA-ED11-2D10-21E9-7BDF4778B228> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x98cab000 - 0x98cabff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x98cea000 - 0x9911fff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x99360000 - 0x9948cfff com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9948d000 - 0x994f7fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x99539000 - 0x99667fe7 com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x99668000 - 0x996d7ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9977d000 - 0x9985aff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0xba900000 - 0xba916ff7 libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <12C58901-CCF3-4E8E-30CA-92A10CD55DF1> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fe7 libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <7FFF4AFA-6522-C7D5-760F-A8F13D6EF032> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
Model: iMac11,1, BootROM IM111.0034.B02, 4 processors, Intel Core i7, 2.8 GHz, 8 GB, SMC 1.54f36
Graphics: ATI Radeon HD 4850, ATI Radeon HD 4850, PCIe, 512 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.9.8.1
Bluetooth: Version 2.3.7f1, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: ST31000528ASQ, 931.51 GB
Serial ATA Device: OPTIARC DVD RW AD-5680H
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfd100000
USB Device: USB to Serial-ATA bridge, 0x1bcf (Sunplus Innovation Technology Inc.), 0x0c31, 0xfd130000
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd110000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0xfd120000
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfa100000
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0xfa120000
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0xfa111000
FireWire Device: 4big Quadra, LaCie, Up to 800 Mb/sec
Version: v1.5.8 (0)
Report Version: 6
Thread 2:
Thread 3:
cr2: 0x00000025
Binary Images:
Director
hah! so true! =DMrTeagan wrote:Same issue here. Won't even open the disc. Crashes. Unfortunate this happens on such a lame chick flick, but my wife is relentless:
- Contact:
Please send MPLS and CLPI files per instructions at http://www.makemkv.com/faq/item/8/catid/6
- Contact:
What exactly is "Rock Star Blu-Unity Encoder" ?MrTeagan wrote:/Applications/Rock Star Blu-Unity Encoder.app/Contents/MacOS/makemkv
File Attached.mike admin wrote:Please send MPLS and CLPI files per instructions at http://www.makemkv.com/faq/item/8/catid/6
