error with The Mechanic (netflix us disc)
tobunk
Post by tobunk » Wed Mar 06, 2019 10:31 pm
Any ideas why this disc won't rip?
Saving 1 titles into directory C:/Video
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '116324352'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '116324352'
DEBUG: Code 3221225628 at Gn,QlSs)zv!z6u9zh1:29395080
DEBUG: Code 100864261 at Gn,QlSs)zv!z6u9zh1:29395080
DEBUG: Code 0 at }vFN@KpabQ2CK7z+-/iZ:29395011
DEBUG: Code 0 at XRO[?3BP.>,Vp$f$!t'x:29394068
DEBUG: Code 0 at }vFN@KpabQ2CK7z+-/iZ:29394459
DEBUG: Code 56799 at }vFN@KpabQ2CK7z+-/iZ:29393286
DEBUG: Code 0 at Si0V5Sd:mgl|*kGOu<s]#:213136608
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file C:/Video/Mechanic_t00.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: error with The Mechanic (netflix us disc)
Post by Woodstock » Wed Mar 06, 2019 11:33 pm
Your drive cannot read parts of it. The first error is where the drive reached a bad spot, then Windows timed out waiting for the drive to STOP trying to read the bad spot.
At the very least, any disk you receive from Netflix or other services should be cleaned before ripping. Sometimes they're too scratched to rip.
