Nothing complicated, I'm probably using non-standard terminology.
Create a new (and therefor empty) directory, eg,
rm -rf $HOME/BUILD
mkdir $HOME/BUILD
unpack the makemkv source in $HOME/BUILD
then build it (in $HOME/BUILD)
MakeMKV broken after upgrade to Ubuntu 18.04
xr200
BohunkG4mer
Re: MakeMKV broken after upgrade to Ubuntu 18.04
I was having the same problem and this fixed it for me. I had to start with a new directoryxr200 wrote: Thu Feb 07, 2019 2:56 pm Nothing complicated, I'm probably using non-standard terminology.
rm -rf $HOME/BUILD
mkdir $HOME/BUILD
gekkentekken
I had to give up eventually, but then I discovered someone had made a flatpak for it! And it solved all my problems.
https://www.flathub.org/apps/details/co ... kv.MakeMKV
pacho014
Hi, I updated to Ubuntu 20 and experienced the exact same problem between the two codecs. How did you resolve the problem?
The topic you replied to is old, and has nothing to do with codecs.
So, if you're having a problem with Ubuntu 20.x, you should begin a new topic and explain what your codec problem is.
