Help is my drive compatible? Wont read uhd
triplerinse
Post by triplerinse » Tue Mar 05, 2019 12:26 am
OS device name: E:
Product: BD-RE WH16NS40
Revision: 1.03
Serial number: SIK9CG8JG321
Firmware date: 2117-11-21 16:53
Highest AACS version: 66
Harware support: Yes
Firmware support: No
Firmware version: 1.03
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
chopedvw
LibreDrive Compatiblity
Post by chopedvw » Tue Mar 05, 2019 1:25 am
I am looking at getting the ASUS BW-16D1X-U External Blu-ray Drive and I am trying to find out if it is compatible with LibreDrive
Re: Help is my drive compatible? Wont read uhd
Post by Woodstock » Tue Mar 05, 2019 1:47 am
ASUS BW-16D1X-U is not UHD-capable.
Post by MartyMcNuts » Tue Mar 05, 2019 2:24 am
triplerinse wrote: Tue Mar 05, 2019 12:26 am Drive Information
OS device name: E:
Revision: 1.03
This drive should work if you downgrade it to 1.02.
chopedvw
Post by chopedvw » Tue Mar 05, 2019 3:17 am
Woodstock wrote: Tue Mar 05, 2019 1:47 am ASUS BW-16D1X-U is not UHD-capable.
Do you have any recommendations on a external UHD and libredrive capable drive?
Post by MartyMcNuts » Tue Mar 05, 2019 11:05 pm
chopedvw wrote: Tue Mar 05, 2019 3:17 am
Yep, an internal drive in a USB external enclosure. Take your pick of drive. BU40N, WH16NS60, ASUS BW-16D1HT, WH16NS40, BH16NS55
Post by Woodstock » Tue Mar 05, 2019 11:47 pm
Best, what Marty said. There are some portable UHD-capable drives, but not many of them are compatible out of the box. The "full size" internal drives are usually much faster and less fragile than most "USB" drives, and the enclosures are not expensive.
I have a LiteOn EB1 drive that is an "official UHD" slim-type USB drive, and it is NOT currently supported by LibreDrive. It would probably work fine with all that official UHD software that will refuse to run on my machines because they aren't "powerful enough to deal with UHD video" (i.e., they won't enforce the copy protection).
figrin_dan
Post by figrin_dan » Thu Mar 07, 2019 11:04 am
MartyMcNuts wrote: Tue Mar 05, 2019 11:05 pm Yep, an internal drive in a USB external enclosure. Take your pick of drive. BU40N, WH16NS60, ASUS BW-16D1HT, WH16NS40, BH16NS55
That's great, if I bought this one now, would it work out of the box or would I need to mess about with the firmware?
Post by Billycar11 » Thu Mar 07, 2019 11:07 am
figrin_dan wrote: Thu Mar 07, 2019 11:04 am
You need to downgrade it most likely
archermoo
Post by archermoo » Thu Mar 07, 2019 3:33 pm
I'm happy with my BU50N. I'm using it as an external drive just by running SATA power and data to it externally. It works with UHD titles out of the box (Firmware BW50). Currently it is supported via LibreDrive for everything but unrestricted read speed.
sgrice
Post by sgrice » Fri Mar 08, 2019 11:43 pm
MartyMcNuts wrote: Tue Mar 05, 2019 2:24 am
OS device name: E:
Revision: 1.03
My WH16NS40 drive is already at 1.02 and I'm still getting the following LibreDrive output:
OS device name: /dev/rdisk2
Revision: 1.02
Serial number: K94D7293705
Firmware date: 2114-05-07 10:26
Drive platform: MT1939
Firmware version: 1.02
Are you sure WH16NS40 will work at all?
Post by MartyMcNuts » Sat Mar 09, 2019 12:39 am
sgrice wrote: Fri Mar 08, 2019 11:43 pm
OS device name: E:
Revision: 1.03
Revision: 1.02
How old is your drive? Does it say SVC NS50 on the label?
M1NG15
Post by M1NG15 » Sat Mar 09, 2019 12:48 am
I have a ASUS BW-16D1HT and LibreDrive is not enabled, any leads on how do I get it enabled?
Post by Woodstock » Sat Mar 09, 2019 2:43 am
What does the info window have as far as information?
Post by MartyMcNuts » Sat Mar 09, 2019 3:15 am
M1NG15 wrote: Sat Mar 09, 2019 12:48 am
Is it a newer model or an older model? What firmware version? If it is a newer drive with 3.03 it will need downgrading to 3.02.
