Help is my drive compatible? Wont read uhd
triplerinse
OS device name: E:
Product: BD-RE WH16NS40
Revision: 1.03
Serial number: SIK9CG8JG321
Firmware date: 2117-11-21 16:53
Highest AACS version: 66
Harware support: Yes
Firmware support: No
Firmware version: 1.03
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
OS device name: E:
Revision: 1.03
LibreDrive Compatiblity
I am looking at getting the ASUS BW-16D1X-U External Blu-ray Drive and I am trying to find out if it is compatible with LibreDrive
Re: Help is my drive compatible? Wont read uhd
ASUS BW-16D1X-U is not UHD-capable.
This drive should work if you downgrade it to 1.02.triplerinse wrote: Tue Mar 05, 2019 12:26 am Drive Information
OS device name: E:
Revision: 1.03
Do you have any recommendations on a external UHD and libredrive capable drive?
Yep, an internal drive in a USB external enclosure. Take your pick of drive. BU40N, WH16NS60, ASUS BW-16D1HT, WH16NS40, BH16NS55
Best, what Marty said. There are some portable UHD-capable drives, but not many of them are compatible out of the box. The "full size" internal drives are usually much faster and less fragile than most "USB" drives, and the enclosures are not expensive.
I have a LiteOn EB1 drive that is an "official UHD" slim-type USB drive, and it is NOT currently supported by LibreDrive. It would probably work fine with all that official UHD software that will refuse to run on my machines because they aren't "powerful enough to deal with UHD video" (i.e., they won't enforce the copy protection).
figrin_dan
That's great, if I bought this one now, would it work out of the box or would I need to mess about with the firmware?MartyMcNuts wrote: Tue Mar 05, 2019 11:05 pm Yep, an internal drive in a USB external enclosure. Take your pick of drive. BU40N, WH16NS60, ASUS BW-16D1HT, WH16NS40, BH16NS55
You need to downgrade it most likelyfigrin_dan wrote: Thu Mar 07, 2019 11:04 amThat's great, if I bought this one now, would it work out of the box or would I need to mess about with the firmware?MartyMcNuts wrote: Tue Mar 05, 2019 11:05 pm Yep, an internal drive in a USB external enclosure. Take your pick of drive. BU40N, WH16NS60, ASUS BW-16D1HT, WH16NS40, BH16NS55
I'm happy with my BU50N. I'm using it as an external drive just by running SATA power and data to it externally. It works with UHD titles out of the box (Firmware BW50). Currently it is supported via LibreDrive for everything but unrestricted read speed.
My WH16NS40 drive is already at 1.02 and I'm still getting the following LibreDrive output:MartyMcNuts wrote: Tue Mar 05, 2019 2:24 amThis drive should work if you downgrade it to 1.02.triplerinse wrote: Tue Mar 05, 2019 12:26 am Drive Information
OS device name: E:
Revision: 1.03
Are you sure WH16NS40 will work at all?Drive Information
OS device name: /dev/rdisk2
Revision: 1.02
Serial number: K94D7293705
Firmware date: 2114-05-07 10:26
Drive platform: MT1939
Firmware version: 1.02
How old is your drive? Does it say SVC NS50 on the label?sgrice wrote: Fri Mar 08, 2019 11:43 pmMy WH16NS40 drive is already at 1.02 and I'm still getting the following LibreDrive output:MartyMcNuts wrote: Tue Mar 05, 2019 2:24 amThis drive should work if you downgrade it to 1.02.triplerinse wrote: Tue Mar 05, 2019 12:26 am Drive Information
OS device name: E:
Revision: 1.03
Unrestricted read speed: Possible, not yet enabledAre you sure WH16NS40 will work at all?Drive Information
Revision: 1.02
I have a ASUS BW-16D1HT and LibreDrive is not enabled, any leads on how do I get it enabled?MartyMcNuts wrote: Tue Mar 05, 2019 11:05 pmYep, an internal drive in a USB external enclosure. Take your pick of drive. BU40N, WH16NS60, ASUS BW-16D1HT, WH16NS40, BH16NS55
What does the info window have as far as information?
Is it a newer model or an older model? What firmware version? If it is a newer drive with 3.03 it will need downgrading to 3.02.M1NG15 wrote: Sat Mar 09, 2019 12:48 amI have a ASUS BW-16D1HT and LibreDrive is not enabled, any leads on how do I get it enabled?MartyMcNuts wrote: Tue Mar 05, 2019 11:05 pmYep, an internal drive in a USB external enclosure. Take your pick of drive. BU40N, WH16NS60, ASUS BW-16D1HT, WH16NS40, BH16NS55chopedvw wrote: Tue Mar 05, 2019 3:17 am
