[Request] Automatic title scanning
mikee
Post by mikee » Mon Mar 04, 2019 7:18 am
I've noticed that when MakeMKV starts up it will automatically scans the disc to show the list of titles.
Can the same be enabled when MakeMKV is already running and a new disc is inserted?
It's already detecting the new drive and presents the huge button, I'm asking for that button to press itself.
Not sure if this is a feature request or it's already possible.
Re: [Request] Automatic title scanning
Post by Woodstock » Mon Mar 04, 2019 1:47 pm
It does? Not that I've seen.
Starting MakeMKV with a disk inserted, the disk gets scanned enough to display its information in the Info window, but I still have to click the Open button to get the directory read.
If no disk is inserted when it is started, inserting a disk takes me to the same screen, and I have to click the Open button to get the directory.
WoofGrrrr
Post by WoofGrrrr » Tue Mar 31, 2020 4:06 pm
One more vote for this. It would speed up ripping disks for me.
When I pop a disk in, I typically get involved with something else and fail to notice when the disk is loaded. The app just sits there, waiting for me to click the Open button.
At the very least, if there could be a reminder, like when initial loading is complete, it would help a bit.
eonmc2
Post by eonmc2 » Fri Mar 20, 2026 6:55 pm
Any update on this? It would be great if MakeMKV could auto-scan and go straight to the title selection automatically.
In the meantime, I put together a PowerShell script as a workaround. It relies on forcing window focus and sending keystrokes, so it might be a bit clunky/unstable, but it gets the job done for now.
# MakeMKV_Opener_Ejector.ps1
# Author: Gemini + Claude Sonnet 4.6 Thinking
# Version: 1.0.5
# Combined Auto-Open-Disc and Auto-Eject Monitor
param(
    [string]$DriveLetter = "D",
    [string]$MakeMKVPath = "C:\Program Files (x86)\MakeMKV\makemkv.exe",
    [string]$LogFile = "$env:USERPROFILE\MakeMKV_log.txt",
    [int]$PollSeconds = 3,
    [int]$MaxScanAttempts = 5,
    [int]$ScanConfirmTimeoutSeconds = 8
if ($DriveLetter -match '([A-Za-z])') {
    $CleanDrive = $matches[1].ToUpper()
} else {
    $CleanDrive = "D"
$root = "${CleanDrive}:\"
$hasRunForLabel = $null
$TempLog = "$env:TEMP\MakeMKV_master_shadow_$PID.txt"
Add-Type @"
using System;
using System.Runtime.InteropServices;
public class WinAPI {
    [DllImport("user32.dll")] public static extern bool ShowWindowAsync(IntPtr hWnd, int nCmdShow);
    [DllImport("user32.dll")] public static extern bool SetForegroundWindow(IntPtr hWnd);
    [DllImport("user32.dll")] public static extern IntPtr GetForegroundWindow();
    [DllImport("user32.dll")] public static extern uint GetWindowThreadProcessId(IntPtr hWnd, IntPtr ProcessId);
    [DllImport("user32.dll")] public static extern bool AttachThreadInput(uint idAttach, uint idAttachTo, bool fAttach);
    [DllImport("kernel32.dll")] public static extern uint GetCurrentThreadId();
    [DllImport("user32.dll")] public static extern bool BlockInput(bool fBlockIt);
function Force-Focus([IntPtr]$hWnd) {
    if ($hWnd -eq [IntPtr]::Zero) { return $false }
    [WinAPI]::ShowWindowAsync($hWnd, 9) | Out-Null
    [WinAPI]::SetForegroundWindow($hWnd) | Out-Null
    $remoteThreadId = [WinAPI]::GetWindowThreadProcessId($hWnd, [IntPtr]::Zero)
    $currentThreadId = [WinAPI]::GetCurrentThreadId()
    if ($remoteThreadId -ne $currentThreadId) {
        [WinAPI]::AttachThreadInput($currentThreadId, $remoteThreadId, $true) | Out-Null
        [WinAPI]::AttachThreadInput($currentThreadId, $remoteThreadId, $false) | Out-Null
    return $true
function Send-OpenDiscMacro($proc) {
    Add-Type -AssemblyName System.Windows.Forms
    if (-not (Force-Focus $proc.MainWindowHandle)) { return $false }
    try {
        [WinAPI]::BlockInput($true) | Out-Null
        Start-Sleep -Milliseconds 300
        [System.Windows.Forms.SendKeys]::SendWait("%(f)")
        Start-Sleep -Milliseconds 400
        [System.Windows.Forms.SendKeys]::SendWait("{DOWN}")
        Start-Sleep -Milliseconds 100
        [System.Windows.Forms.SendKeys]::SendWait("{RIGHT}")
        [System.Windows.Forms.SendKeys]::SendWait("{ENTER}")
        return $true
    } finally {
        [WinAPI]::BlockInput($false) | Out-Null
function Wait-ForReadySignal($baselineLines, $timeoutSeconds, $SourceLog, $ShadowLog) {
    $readyPattern = 'SDF id v'
    $deadline = (Get-Date).AddSeconds($timeoutSeconds)
    $bl = $baselineLines
    while ((Get-Date) -lt $deadline) {
        Copy-Item -LiteralPath $SourceLog -Destination $ShadowLog -Force -ErrorAction SilentlyContinue
        if (Test-Path $ShadowLog) {
            $allLines = @(Get-Content $ShadowLog -Encoding UTF8 -ErrorAction SilentlyContinue)
            if ($allLines.Count -lt $bl) { $bl = 0 }
            $newLines = $allLines | Select-Object -Skip $bl
            if ($newLines | Where-Object { $_ -match $readyPattern }) {
                return $true
        Start-Sleep -Milliseconds 500
    return $false
function Wait-ForLogLine($baselineLines, $timeoutSeconds, $SourceLog, $ShadowLog) {
    $successPattern = 'Using direct disc access mode|Launching.*mmgplsrv64\.exe|Title #\d+ was added'
        if (Test-Path $SourceLog) {
                    $bl = 0
                if ($newLines | Where-Object { $_ -match $successPattern }) {
                    return $true
    return $false
Write-Host "=== MakeMKV Opener & Ejector Monitor ===" -ForegroundColor Cyan
Write-Host "Watching drive $CleanDrive for new discs and rip completions..." -ForegroundColor Gray
$lastSize = 0
$seenLines = 0
if (Test-Path $LogFile) {
    Copy-Item -LiteralPath $LogFile -Destination $TempLog -Force -ErrorAction SilentlyContinue
    if (Test-Path $TempLog) {
        $lastSize = (Get-Item $TempLog).Length
        $seenLines = @(Get-Content $TempLog -Encoding UTF8 -ErrorAction SilentlyContinue).Count
try {
    while ($true) {
        try {
            $di = New-Object System.IO.DriveInfo($root)
            # --- 1. SCAN LOGIC ---
            if ($di.IsReady) {
                $label = $di.VolumeLabel
                if (-not $label) { $label = "__NO_LABEL__" }
                if ($hasRunForLabel -ne $label) {
                    Write-Host "`n$(Get-Date -Format 'HH:mm:ss') -> New disc detected: $label" -ForegroundColor Green
                    $hasRunForLabel = $label
                    $proc = Get-Process makemkv -ErrorAction SilentlyContinue |
                            Where-Object { $_.MainWindowHandle -ne 0 } |
                            Select-Object -First 1
                    if (-not $proc) {
                        Write-Host "Launching MakeMKV..." -ForegroundColor DarkGray
                        Start-Process -FilePath $MakeMKVPath -WindowStyle Normal
                        $waited = 0
                        while ($waited -lt 15) {
                            Start-Sleep -Seconds 1
                            $waited++
                            if ($proc) { break }
                    if ($proc) {
                        $baselineLines = 0
                                $baselineLines = @(Get-Content $TempLog -Encoding UTF8 -ErrorAction SilentlyContinue).Count
                        Write-Host "Waiting for MakeMKV ready signal (SDF id)..." -ForegroundColor DarkGray
                        if (-not (Wait-ForReadySignal $baselineLines 60 $LogFile $TempLog)) {
                            Write-Host "MakeMKV did not become ready in time." -ForegroundColor Red
                        } else {
                            Write-Host "MakeMKV ready. Sending Open Disc macro..." -ForegroundColor DarkGray
                            $scanConfirmed = $false
                            for ($attempt = 1; $attempt -le $MaxScanAttempts; $attempt++) {
                                Write-Host "Sending scan command (attempt $attempt)..." -ForegroundColor DarkGray
                                Send-OpenDiscMacro $proc | Out-Null
                                Write-Host "Waiting for scan confirmation in log (${ScanConfirmTimeoutSeconds}s)..." -ForegroundColor DarkGray
                                if (Wait-ForLogLine $baselineLines $ScanConfirmTimeoutSeconds $LogFile $TempLog) {
                                    Write-Host "Scan confirmed!" -ForegroundColor Green
                                    $scanConfirmed = $true
                                    break
                                } else {
                                    Write-Host "Not confirmed yet, retrying..." -ForegroundColor Yellow
                            if (-not $scanConfirmed) {
                                Write-Host "Scan could not be confirmed after $MaxScanAttempts attempts." -ForegroundColor Red
                    } else {
                        Write-Host "MakeMKV did not start in time." -ForegroundColor Red
                    continue
            } else {
                if ($null -ne $hasRunForLabel) {
                    Write-Host "$(Get-Date -Format 'HH:mm:ss') -> Disc removed." -ForegroundColor DarkGray
            # --- 2. EJECT LOGIC ---
                    $currentSize = (Get-Item $TempLog).Length
                    if ($currentSize -gt $lastSize) {
                        $allLines = @(Get-Content $TempLog -Encoding UTF8 -ErrorAction SilentlyContinue)
                        if ($allLines.Count -lt $seenLines) {
                            $seenLines = 0
                        $newLines = $allLines | Select-Object -Skip $seenLines
                        $seenLines = $allLines.Count
                        $lastSize = $currentSize
                        foreach ($line in $newLines) {
                            if ($line -match 'Copy complete\. (\d+) titles? saved') {
                                $titleCount = [int]$matches[1]
                                if ($titleCount -eq 0) { continue }
                                Write-Host "`n>>> RIP COMPLETE! ($titleCount titles saved) <<<" -ForegroundColor Green
                                Write-Host "Closing MakeMKV popup..." -ForegroundColor Cyan
                                if ($proc) {
                                    $popupClosed = $false
                                    $attempt = 0
                                    while (-not $popupClosed -and $attempt -lt 3) {
                                        $attempt++
                                        Start-Sleep -Seconds 3
                                        try {
                                            [WinAPI]::ShowWindowAsync($proc.MainWindowHandle, 9) | Out-Null
                                            [WinAPI]::SetForegroundWindow($proc.MainWindowHandle) | Out-Null
                                            Start-Sleep -Milliseconds 600
                                            [System.Windows.Forms.SendKeys]::SendWait(" ")
                                            Start-Sleep -Milliseconds 200
                                            [System.Windows.Forms.SendKeys]::SendWait("{ESC}")
                                            Write-Host "Popup keystrokes sent (attempt $attempt)." -ForegroundColor Green
                                            $popupClosed = $true
                                        } finally {
                                } else {
                                    Write-Host "MakeMKV GUI process not found." -ForegroundColor Yellow
                                if ($titleCount -eq 1) {
                                    Write-Host "Single title saved. Ejecting drive..." -ForegroundColor Green
                                    $ejected = $false
                                    try {
                                        $wmp = New-Object -ComObject WMPlayer.OCX.7
                                        $cdroms = $wmp.cdromCollection
                                        for ($i = 0; $i -lt $cdroms.Count; $i++) {
                                            if ($cdroms.Item($i).DriveSpecifier -match "^$CleanDrive") {
                                                $cdroms.Item($i).Eject()
                                                $ejected = $true
                                                break
                                        if (-not $ejected) { throw "Not in WMP" }
                                    } catch {
                                        try {
                                            $shell = New-Object -ComObject Shell.Application
                                            $shell.Namespace(17).ParseName("$CleanDrive`:").InvokeVerb("Eject")
                                        } catch {
                                            if ($proc) {
                                                Write-Host "COM Eject failed, using Menu fallback..." -ForegroundColor Yellow
                                                try {
                                                    [System.Windows.Forms.SendKeys]::SendWait("e")
                                                } finally {
                                } else {
                                    Write-Host "Multiple titles ($titleCount) saved. TV Series Mode: Eject SKIPPED." -ForegroundColor Magenta
                                Write-Host "Playing completion sound..." -ForegroundColor Yellow
                                for ($i = 1; $i -le 4; $i++) {
                                    [System.Console]::Beep(750, 500)
                                $wavPaths = @(
                                    "C:\Program Files (x86)\Elaborate Bytes\CloneDVD2\sounds\success.wav",
                                    "C:\Program Files (x86)\DVD Decrypter\Sounds\Success.wav",
                                    "C:\Program Files (x86)\ImgBurn\Sounds\Success.wav",
                                    "C:\Windows\Media\tada.wav"
                                foreach ($wav in $wavPaths) {
                                    if (Test-Path $wav) {
                                        try {
                                            $player = New-Object System.Media.SoundPlayer
                                            $player.SoundLocation = $wav
                                            $player.PlaySync()
                                            break
                                        } catch { }
                                Write-Host "Waiting for the next disc..." -ForegroundColor Cyan
                                break
        } catch { }
        Start-Sleep -Seconds $PollSeconds
} finally {
    Remove-Item $TempLog -Force -ErrorAction SilentlyContinue
