Heads up - Support for LG UHD drives
jkeener88
Re: Heads up - Support for LG UHD drives
Post by jkeener88 »
jsuaggie wrote: Wed Jan 30, 2019 1:59 am
jkeener88 wrote: Tue Jan 15, 2019 2:50 pm Owner of a ASUS BW-16D1HT, on its way, should have it next week! :mrgreen:
Where did you purchase your drive? I hope it comes with the "UHD Friendly" firmware.
Got it on ebay, works like a champ!
ASUS BW-16D1HT 3.01
jonghotti
Post by jonghotti »
If you're going to buy a drive, buy it here, don't support those guys on eBay.
nicksilverstein
Post by nicksilverstein »
jonghotti wrote: Fri Feb 08, 2019 11:45 pm Yes it needs to be flashed with BU40N 1.00 which I am happy to send you. Alternatively I'll swap you a BU50N with supported firmware for yours.
Do you still have the BU40N 1.00 firmware? Can you please send it to me?
Dave77
Post by Dave77 »
Hi, mine reads the following, will it be supported in the future?
Product: BD-RE WH16NS60
Revision: 1.01
Harware support: Yes
Firmware support: No
Firmware version: 1.01
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
spl147
Post by spl147 »
Dave77 wrote:Hi, mine reads the following, will it be supported in the future?
Revision: 1.01
Use the LG patched flasher and the 1.0 DE enabled firmware and you can use it now
Sent from my iPhone Xs Max using Tapatalk Pro
Dave77
Post by Dave77 »
spl147 wrote: Fri Mar 08, 2019 12:53 pm Use the LG patched flasher and the 1.0 DE enabled firmware and you can use it now
Thanks. Do you have a link to instructions, I can find lots on the Asus but not the LG
Post by d00zah »
Dave77 wrote: Fri Mar 08, 2019 1:47 pm Thanks. Do you have a link to instructions, I can find lots on the Asus but not the LG
1st link in this thread:
viewtopic.php?f=16&t=18933#p70766
is to an archive containing both the tool & the prepared firmware images.
xxcalibur
Post by xxcalibur »
hey fellas. i just purchased the same LG drive as Dave77. i'd like to start using my drive to backup my 4k collection and after reading this thread i just wanted to get confirmation that im using the right tool and firmware. i've grabbed the zip file containing the asus tool and firmware. so if i use the asus tool and this firmware:
"DE_LG WH16NS60_1.00.bin" i'll get good to go?
spl147 said to use the "Use the LG patched flasher" but i only see the asus one in the zip file..is that considered the same?
thanks guys, i appreciate everything you all do for this group
xxcalibur
Dave77
Post by Dave77 »
xxcalibur wrote: Sat Mar 09, 2019 1:41 pm hey fellas. i just purchased the same LG drive as Dave77.
V1.01 is going to be supported soon apparently, might be worth waiting a bit.
xxcalibur
Post by xxcalibur »
Cool. Thanks Dave. I'd rather not flash and run the risk of screwing up the drive.
Thanks again.
Xxcalibur
xxcalibur wrote: Sat Mar 09, 2019 1:41 pm hey fellas. i just purchased the same LG drive as Dave77. i'd like to start using my drive to backup my 4k collection and after reading this thread i just wanted to get confirmation that im using the right tool and firmware. i've grabbed the zip file containing the asus tool and firmware. so if i use the asus tool and this firmware:
xxcalibur
Correct. FYI, Both the modified ASUS tool and the LG tool do the same thing.
xxcalibur
Post by xxcalibur »
thanks for clarification MartyMcNuts :D
plittlefield
Post by plittlefield »
Hi Folks,
I have just bought a WH14NS40 with SVC: NS50 and firmware 1.03 manufactured in November 2018.
Is this the correct forum thread or should I buy the WH16NS60 instead?
Thanks,
Paully
plittlefield wrote: Sun Mar 10, 2019 9:34 pm Hi Folks,
Thanks,
Paully
that will work follow my how to video here: https://www.youtube.com/watch?v=Yfpf6HoMMis
