Ben Is Back (2018) playlist obfuscation
ChrisCaPWN
Post by ChrisCaPWN »
Ben Is Back (2018)
https://www.imdb.com/title/tt7545524/?ref_=nv_sr_3
Here is the correct playlist for Ben Is Back. :D
Title information
Name: Ben Is Back
Source file name: 00599.mpls
Duration: 1:43:18
Chapters count: 16
Segment count: 20
Segment map: 502,512,511,504,505,514,509,513,500,501,506,508,507,518,503,516,510,519,517,515
File name: Ben Is Back_t241.mkv
I am still struggling to dump out the disc data from MakeMKV to a text file using Command Prompt, so I went line by line to find the correct playlist. If anyone can offer any help on doing this, that would be most appreciated.
Cheers,
-Chris
Steveredrum
Re: Ben Is Back (2018) playlist obfuscation
Post by Steveredrum »
ChrisCaPWN wrote:
Sat Mar 02, 2019 6:17 pm
Ben Is Back (2018)
Title information
Name: Ben Is Back
Duration: 1:43:18
Chapters count: 16
Segment count: 20
Cheers,
-Chris
Just To Confirm This Is Working For Me Thanks [Used For An Un-touched Blu-ray Version Of The Film]
Petryfied
Post by Petryfied »
Anybody know the correct playlist for RB disk?
swampdaddy
Post by swampdaddy »
My retail disc was damaged.... I acquired a Netflix disc.... so, what playlist is valid?
How did you guys figure this out?
Thanks,
R
flintstone198
Post by flintstone198 »
swampdaddy wrote:
Mon Aug 12, 2019 9:17 pm
Thanks,
R
I found the netfilx version to have the same playlist as the retail. 00599.mpls
This is all hypothetical for discussion purposes only. Figured it out by backing up the disc, with encryption removed, with makemkv. Then watch the movie in a bluray player and then note the order of the m2ts files from the backup. Then to find the mpls I look thru the all the playlist mpls files to find the one with the correct file order listed. This last bit is easier with help from a simple ms office macro. This is all hypothetical for discussion purposes only.
I have seen posts that mention how to find the correct playlist using a software program. so look around for that.
