MAKEMKV renewal
All topics related to functioning of this forum or MakeMKV website
geterdone68
MAKEMKV renewal
Post by geterdone68 »
I purchased a copy of MAKEMKV BETA months ago, and just noticed a request for registration. I attained and entered the registration code. I also just registered online for the (I think,) the first time. Have I voided my original purchase?
Re: MAKEMKV renewal
If you put the beta key in, it's in beta mode. But, it wouldn't have asked if you had your permanent key in, so...
Find your email from avangate.com or 2co.co, which will have your permanent key. You can enter that at any time, same way as with the beta key, and you shouldn't be asked again.
dascubadude
Re: MAKEMKV renewal
Post by dascubadude »
Hello I was using the beta version and would like to find out; how much it is for a key and how to get one? thank you 8)
Re: MAKEMKV renewal
Help->Buy in the program will take you to the page https://makemkv.com/buy/ , which will give you full information and the opportunity to get your key.
